If you mean by taking pics with your phone, I’ve used my phone several time in tough to see areas. For instance I’ve used it to take a clear close up shot of the turbo wheel so that I could inspect it. The turbo internals are hard to see close up without a little help from your phone.
You might be able to see where the oil is coming from by viewing from underneath a properly supported car. A camera phone might help you view the area up around the intake and exhaust.
However these cars are known for valve cover leaks, so if the oil is coming from near the top it’s likely the valve cover. Most of us will remove the cover make sure the sealing surface is flat and clean add some RTV to those surfaces and torque it down to spec. Which is less than 10 foot lbs if I remember.
