Sharpshooter48
I have a 1.9 tdi alh automatic, first i bought this car with a bad transmission with the intention to do a swap build, with that being said it had what sounded like a lope tune but was told it was completely stock. I dove in started trouble shooting first codes i had were (quantity adjusted upper limit attained), (needle lift sensor circ. Open/short to b+),(throttle pedal position sensor/switch C high), and (coolant thermostat below regulating temperature). I did a full timing belt change with everything included an i bought a new fuel injection pump. After all that plus new vacuum lines the car has lost the lope tune sound but idles a little high an is white smoking bad. I have messed with the injection pump got the idle normal but still around 1k-1,200 rpms an white smoking. And it is still throwing the (needle lift sensor circ. Open/short to b+), can anyone help on whats going on, i have a vcds cable from ross tech coming in the mail but is there anything else that could help?
