Hello,
I am selling this car ($4500) because I bought a newer car. This car is very reliable and the parts are very inexpensive to replace (if need be). I have replaced loads of parts on this car, i.e. all of the suspension, except for the subframe bushings (still good). I have a lot of receipts (Paper & digital) to show the work was done. A/C is cold, heat is hot, 40-45 MPG.
Call or text 850-586-9058
I will accept cash or check, but both will be done at a bank to verify the money.
Current Mileage = 233,850 (Gets driven around the neighborhood to keep everything lubricated & the battery gets trickle charged once a week)
**Pros
-- Now has a better steering wheel (Multi-functions do not work) & handbrake knob
-- Comes with three working keys (One is waterproof), and one top half
-- Dieselgeek skidplate with side protection panels+ Dieselgeek short shifter + Dieselgeek shifter shaft bushing
-- Malone Stage 1 tune
-- Dimple engine magnetic drain plug
-- Rayno S9 window tint all around, except for the windshield. The windshield has Rayno 7090 platinum tint on it (Not noticeable by sight, but definitely by heat reduction) (Total was $696 and done by Rob at Glass Wrap in Pensacola -- Best of the best!)
-- Soumatrix Inspirit VHK4 speakers (All four)
** Cons
-- Minor vibration when braking (Stripped out front left brake mount, but it is secured with bolt & nut w/ red Loctite)
-- Turn signals flash quite quickly due to LED bulbs
-- Clear coat peeling or gone in certain areas of the car
** Here is the maintenance history **
Timing Components @ 223,300 (100K -- Dieselgeek Kit)
A/C compressor & Expansion Valve @ 224,149
A/C Drier @ 224,149
Transmission Oil @ 217,192
Engine Oil & Filter @ 232,908
Engine & Coolant Glow Plugs @ 227,800
Fuel Filter @ 227,684
Coolant Fluid @ 220,500
Power Steering Fluid @ 217,650
Brake Fluid @217,650
Cabin Filter @ 217,085
Intake Filter @ 217,085
Complete Suspension (Except Subframe Mounts) @ 217,640
Rotated all four tires @ 229,861
Front, Mid, Rear Brake lines @ 217,650
All Four Wheel Bearings @ ~219,000
All Brake Pads & Rotors @ 218,915
DMF Clutch Complete Kit@ 219,950
Engine, Transmission, & Dogbone Mounts @ 220,000
Alternator @ 223,553
Starter @ 217,640
**Pros
** Cons
A/C Drier @ 224,149
Starter @ 217,640
