2001 VW Jetta TDI (Manual) Navarre, FL
WhealtonS
Florida
2001 VW JETTA TDI
Hello,
I am selling this car ($4500) because I bought a newer car. This car is very reliable and the parts are very inexpensive to replace (if need be). I have replaced loads of parts on this car, i.e. all of the suspension, except for the subframe bushings (still good). I have a lot of receipts (Paper & digital) to show the work was done. A/C is cold, heat is hot, 40-45 MPG.
Call or text 850-586-9058
I will accept cash or check, but both will be done at a bank to verify the money.
Current Mileage = 233,850 (Gets driven around the neighborhood to keep everything lubricated & the battery gets trickle charged once a week)
**Pros
-- Now has a better steering wheel (Multi-functions do not work) & handbrake knob
-- Comes with three working keys (One is waterproof), and one top half
-- Dieselgeek skidplate with side protection panels+ Dieselgeek short shifter + Dieselgeek shifter shaft bushing
-- Malone Stage 1 tune
-- Dimple engine magnetic drain plug
-- Rayno S9 window tint all around, except for the windshield. The windshield has Rayno 7090 platinum tint on it (Not noticeable by sight, but definitely by heat reduction) (Total was $696 and done by Rob at Glass Wrap in Pensacola -- Best of the best!)
-- Soumatrix Inspirit VHK4 speakers (All four)
** Cons
-- Minor vibration when braking (Stripped out front left brake mount, but it is secured with bolt & nut w/ red Loctite)
-- Turn signals flash quite quickly due to LED bulbs
-- Clear coat peeling or gone in certain areas of the car
** Here is the maintenance history **
Timing Components @ 223,300 (100K -- Dieselgeek Kit)
A/C compressor & Expansion Valve @ 224,149
A/C Drier @ 224,149
Transmission Oil @ 217,192
Engine Oil & Filter @ 232,908
Engine & Coolant Glow Plugs @ 227,800
Fuel Filter @ 227,684
Coolant Fluid @ 220,500
Power Steering Fluid @ 217,650
Brake Fluid @217,650
Cabin Filter @ 217,085
Intake Filter @ 217,085
Complete Suspension (Except Subframe Mounts) @ 217,640
Rotated all four tires @ 229,861
Front, Mid, Rear Brake lines @ 217,650
All Four Wheel Bearings @ ~219,000
All Brake Pads & Rotors @ 218,915
DMF Clutch Complete Kit@ 219,950
Engine, Transmission, & Dogbone Mounts @ 220,000
Alternator @ 223,553
Starter @ 217,640
calimustang
Central FL
2011 JSW DSG (buyback, RIP), 2015 Passat TDI SE, 2014 JSW TDI.
What price are you asking? What color is the car? Any rust?
WhealtonS
Florida
2001 VW JETTA TDI
I am asking $4500, the car is silver and there are only small rust spots from when small rocks hit the hood and the top portion windshield/roof. Someone in my area keeps flagging my Craigslist post idk why, but it is annoying. I will be adding the pictures in a little bit.
calimustang
Central FL
Very nice overall. Where did you get those fuel injection tubes from? I truly like it!
The CL flagger probably is jealous of your ride ;)
WhealtonS
Florida
2001 VW JETTA TDI
-- I bought the fuel injection tubes from McMaster-Carr
*Crack-Resistant Teflon PFA Clear Tubing for Chemicals (4mm ID, 6mm OD)
It was a pain in the ass to make it fit without putting bends in the tubing, but with time and patience it worked out (No bends).
calimustang
Central FL
Thanks for sharing. :) I wish you good luck w the sale. I know you will miss her a lot once she is gone.
WhealtonS
Florida
2001 VW JETTA TDI
Thank you for the luck and conversation. With all of the time I've spent refreshing her and the trips she's been on, I'll definitely miss her.
