2001 Jetta ALH Part out. KCMO area
aminal_99
Belton, MO
2001 Jetta MK4 TDI
Totaled my car 239,812 Miles. It's an automatic. the car took damage to its entire body (slid on snow/ice under center median cables) no frame/engine damage. Everything still worked, and I took a video of it running, I actually drove it home after the accident.
not interested in selling every nut and bolt here guys, I have pulled the engine though but the tranny is not for sale. I've raped a lot of parts off of the engine so I'm holding that to any one local that may need the block and/or head (which I may decide to keep the head). Also, if your local, grey cloth HEATED SEATS! so warm!!!
if your interested PM me your offers. If your offer speaks to me i'll pm you back and we will work out the details. trying to be fair to everyone here, including myself. If I don't get reasonable offers I will start listing prices ...just don't laugh at them! otherwise they will be put up on ebay, but I figured this would be easier for everyone.
I've never done a part out like this but I need to generate some funds quickly!
the parts i'm most interested in selling (and are already pulled off) are:
Turbo
11mm Injection pump with gear
intercooler - SOLD
Fuel injectors, selling as set
fuel injector hard supply lines
Heated Seats (Local Only)
Starter
fans
grey glove box
TPS
ECU
TCU
6 disc changer
cd unit
radio with tape deck unit
egr valve
egr cooler
grey cloth center arm rest
ac/alternator mounting braket
a/c (pig tail connection cracked)
alternator 90amp
power steering pump
MAF
Stock MAP sensor
head lamp assemblies
side quarter panel lights
amber side marker lights
rear driver tail light only.
battery box assembly
visors.
steering wheel and air bag (no controls)
I might consider taking out window regulators for those interested.
Like I said, unless your local I don't want to pull every piece off the car and ship it, but if your in need of something it couldn't hurt to ask and i'll let you know if i'm willing to box it up for you.
McFarlin109
Hot Springs, AR
2000 Jetta TDI 5-speed Black 220k and still going strong, 2000 Jetta TDI white 5-speed 128k(parting out)
Do you have the driver side mirror? What color and is it manual, power, and/or heated? Thanks
aminal_99
Belton, MO
2001 Jetta MK4 TDI
Mirrors were both broke off, sorry.
curiously, they were power...but these things come with a heated option too?
jhonster
Los Angeles, Ca.
2013 Jetta Sportwagen, , 2001 Jetta, 2000 Jetta
Interested in the EGR valve assm if it's still working and diaphragm nipple isn't busted. An oil pan if you're selling it. Also the intercooler for my moms car. Please send an email to iamtheeggman1@gmail.com with how much you want and what's available. lastly, would you send to Los Angeles? Thanks! John.
bdub
WI
Mk4 Jetta, Mk4 Golf 2dr 5spd
Looking for rear defrost switch with wiring and antenna base if it isn't all corroded. Let me know on shipping to 53523. Thanks!
aminal_99
Belton, MO
2001 Jetta MK4 TDI
RikAmirnov, Huh?
bdub, the antenna is no good. I've been trying to pry out the center vents with the switches in tact, I can't get that figured out.
Hirak
Williamsburg, VA
2001 Black
Typically when you disconnect power from the radio it will require a four digit code to unlock the radio. Otherwise it will stay in a locked mode.
aminal_99
Belton, MO
2001 Jetta MK4 TDI
I guess I can test fit it on my other 2001 Jetta and see if it works.
are you wanting radio unit only, or the single disc player unit as well?
aminal_99
Belton, MO
2001 Jetta MK4 TDI
Guys,
We just had a baby on the 21st of April, if it takes some time to respond I'm sure you'll understand why, please be patient with me if you are in need of some parts.
aminal_99
Belton, MO
2001 Jetta MK4 TDI
700 raptor, I pm'd you. I do have it.
I also have a raptor 660 bored out to 680I think it was, still need to finish rebuilding it though.
thecrusher773
Coweta, OK
2002 5 Speed Beetle-sold, 2010 Jetta-sold 2014 Beetle
I might be interested in the battery box stuff. Not sure if it's the same as a beetle though. Also local would just come by and pickup.
aminal_99
Belton, MO
2001 Jetta MK4 TDI
Bump, sorry if I haven't gotten back with some of you. If your still interested please PM me, i'll likely respond to those better than forum posts.
