2000 beetle tdi manual
IvanG100
Houston Tx
2000 beetle tdi
Just bout a 2000 beetle Tdi fell in love with it but was having trouble putting it in reverse and 2nd gear I noticed that someone had rigged the gear shift lever and welded a different part too it I went to 10 different pick and pulls and could not find this exact lever so I decided to order it it’s a bit pricey but I cannot find the bolt or the catch that grabs on to the cable link does anyone know where I can find it or how’s it supposed to look like ?
IvanG100
Houston Tx
2000 beetle tdi
The part you have pictured is a 98/99 beetle. The 2000 beetle has the newer style shift relay lever. Can you post a pic of your actual shift mechanism?
So it’s practically going to be impossible finding that part ? lol since it’s only two year margin ?
jimbote
Certified Volkswagen Nut
Tacoma 4x4 converted to TDI
Looking closer at your pics, you have the late cables with an early tower. The two are not compatible. So you need a late tower assembly to complete the package. Check your inbox for a second message. I have the tower.
