2000 ALH vs. 2003 ALH
1975 Kombi
Acton, Ontario, Canada
2003 TDI Jetta, 2011 Touareg TDI, 1992 D Jetta, 1992 TD Jetta, 2001 NB TDI, 1992 Golf coupe D
I currently have a 2003 Jetta with a failing ALH and was wondering if a 2000 ALH would be a direct fit on the electronic side of things. Or if there are any differences in the 2 motors. I was hoping to use the 2003 ECU and wiring.
Fix_Until_Broke
03 Jetta, 03 TT TDI
The only thing I can think of is that the 2003 injector #3 plug is a D shaped whereas all the earlier ones are 0 shaped.
There may be other minor things like that, but I believe they're all functionally the same.
Nero Morg
OR
I've done that swap, put a 2000 engine in my current 2003, only thing you have to change is the 3rd injector connector.
Metal Man
Sunbury,PA 17801
1998 NB TDI, 2006 Jetta TDI, 2014 Tiguan gas, , 2019 E Golf X2
The motor would be a straight forward swap. If you swap the ECU and wiring, that may complicate things.
Edit to add now I see I read your post wrong. I was thinking you wanted to put the 03 items in an 2000.
The only difference is the lift sensor connector on #3 injector (which can be depinned and swapped, the function is the same) and the glow plug circuit. 2000 still has a 2-channel ON/OFF glow system, 2003 will have the 4-channel duty cycled system. So the glow control unit is different as is the wire harness.
But the glow PLUGS are the same. So if you have a complete 2003 harness, you can attach it to the 2000 engine and it will work just fine.
1975 Kombi
Awesome thanks everyone. I will try and keep the 2003 wiring intact and just switch the #3 injector. Thanks
jokila
Houston, Texas
2003 Jetta GLS, Manual
While the engines are the same there are differences in the things you attach to it. As already mentioned about the injector connector and glowplug circuits, depending on the transmission, you would might need to swap the configuration on the coolant flange to the back of the motor as it would have the coolant glow plugs.
If you are getting a long block much of this you would be reusing off of your engine anyway so it should be as simple as transferring the parts to the replacement engine. I would recommend you purchase new gaskets to make sure you don't have leaks putting this all together.
Nero Morg
OR
Speaking of, if you have the flange for an automatic (composite plastic) you may want to order a replacement, as they like to deteriorate over time. Same with the thermostat housing.
There are small differences in the engines, such as the engine mount bracket hole is a bit beefier on the 03 block, but it'll still all bolt up the same.
mrfiat
Los Ranchos, NM
2003 Jetta TDI (Reflex Silver) , 2003 Jetta TDI Wagon (Black)
Some of the early 2003s have the earlier #3 injector connector. (I have one of those) My other 2003 has the newer type of connector.
