200 miles until no start question
1968RT
Wisconsin
2013 CKRA Passat
I have a bad nox sensor in a 2013 passat that triggered a "no start in 200 miles" count down.
I waiting too long to replace the sensor. I picked one up at the dealer this morning after the countdown has begun.
Once the system is happy with the nox readings again & the reductant system is working as intended, how many miles will it typically take
for the adblue warning to go away?
TurboABA
Kitchener, ON
No one can answer anything like that until we see a full scan to know exactly what the current situation is.
1968RT
Wisconsin
2013 CKRA Passat
Wasnt looking to bother anyone with troubleshooting, I already know the NOX sensor is bad, I just have not taken the time to change it.
So my question was really just wondering if the adblue 200 mile count down would auto clear once the issue that caused it is corrected.
I guess I will find out soon enough, I was just curious
privateTDIjet
Montreal, Canada
2009 Jetta 2.0 TDI and 2014 Passat 2.0 TDI
I had a bad NOx sensor on my 14 passat and never got the message. Once replaced, code went away instantly. Im surprised you bought it from the dealer, how much did they charge you?
Dont forget to tighten the plastic cover correctly, mine had broken tabs which let loose while driving.
TurboABA
Kitchener, ON
A NOx sensor won't cause a death countdown.
The answer to your questions is "it will never auto clear".
This is because you have another issue, but since you don't want to bother others with troubleshooting, you don't know what that is.
(or are ignoring it)
