How many miles on it with 2 stroke?Ashless 2 stoke, powerservice gray or white, powerservice clean diesel, powerservice biocide and enough biodiesel added to make one gallon. Been running this since new (first tank!) No problems. Runs great!
200:1 ratio... does not turn the fuel green. His pump is not going to poof either. I recommend using DEI heat shield products to insulate the fuel lines, rail, insulate the fuel canister and bypass the t-stat valve in the fuel canister and route fuel back to the tank. Remove the possibility of heat soaking the fuel lines and provide the coolest fuel coming out of the tank to pull heat off the HPFP.Only problem is this stuff is green. As in really really dark green. If your hpfp goes poof and they dip yer tank or if you go to VW for routine service and they dip your tank (yes they can do this!) then man you are stone cold busted. You can always try and pump the tank and fuel filter canister out and refill with some virgin d2 before you call the wrecker...not that I would advocate such behavior hahaha!
2 stroke oil is designed to lubricate bearings, seals, rings, piston pin and the piston-skirt to bore, so yes, adding it to diesel does lubricate things, thus avoiding metal to metal contact. The new stuff, IE TCW is designed to burn clean so it doesn't gum up the parts and produce smoke like the old days.I don't understand this dedication to 2 stroke oil. 2 Stroke oil was designed to lubricate a crankcase charged 2 stroke engine without fouling the spark plug. It is not a better lubricant than most 4 stroke oils. A 4 stroke oil in a 2 stroke engine will foul the plug very quickly. A 4 stroke oil in diesel fuel will simply burn.
Sez who? You2 stroke oil is designed to lubricate bearings, seals, rings, piston pin and the piston-skirt to bore, so yes, adding it to diesel does lubricate things, thus avoiding metal to metal contact. The new stuff, IE TCW is designed to burn clean so it doesn't gum up the parts and produce smoke like the old days.
No, the makers of 2 stroke oil, and a few people who have tested it's properties against wear, DURRRR!Sez who? You
I use 16oz of 2 stroke oil per tankful, 8oz of all the powerservice products except the biocide (2oz is plenty) and the balance b100 to equal one gallon total. I change the oil, oil filter and fuel filter every 5000 miles. Is this overkill? Probably so as the fuel filter is quite clean when I change it. I have seen no metal shavings in the filter housing so far. 20k miles...stay tunedHow many miles on it with 2 stroke?
What ratio? (oz per gallons or tank)
You should keep track of the dpf ash if you have a dpf with that much 2 stroke. I know at the 200:1 ratio there is no problems so far with 26000 miles of use. I dont recall seeing which year you have but if its a cr motor i would recommend continuing to swap the fuel filter every 10k...I use 16oz of 2 stroke oil per tankful, 8oz of all the powerservice products except the biocide (2oz is plenty) and the balance b100 to equal one gallon total. I change the oil, oil filter and fuel filter every 5000 miles. Is this overkill? Probably so as the fuel filter is quite clean when I change it. I have seen no metal shavings in the filter housing so far. 20k miles...stay tuned
Yeah it is...Mine is a 2012. Watching the DPF ash load does sound like a good idea.
Thanks Mark.I was impressed with Abacus' results with a mix of 2 Stroke oil and Power Service and have been running this in my TDI Bus.
I was impressed with Abacus' results with a mix of 2 Stroke oil and Power Service and have been running this in my TDI Bus. I recently ran out of 2 Stroke and went to the local FLAPS and found this stuff:
Pennzoil Marine® XLF
Their claim "...formulated to a higher lubricity limit than the NMMA AF-27 lubricity test..."
They also sell a regular TCW3 oil, so presumably this oil has more lubricity than that. TDI benefit? Who knows, but thought I'd pass the info along.
Full product page: http://www.pennzoil.com/other-car-p...rd-engine-oil-extended-life-formula/#Benefits
Mark
I'd be interested to see what you get just running the B5 and Optilube. Particularly the 3rd tank once everything else has been flushed out.I run B5 and optilube and 2 stroke oil. 6 oz two stroke oil 2 oz optilube boost and 6 oz XPD per tank. Filled up today and calculator netted 52 mpg for the tank.
Feel free to provide input.Can't believe a thread I started is still going, must be because I stay out of it lol
That has not been my experience over hundreds of thousands of miles in a real world application (my car). But then I mix it with a cetane improver at 1/2 the ratio as well, so it's not straight 2 cycle oil. In addition, the injection pump is audibly quieter which is why I add it.Has anyone else here seen this test from Sasol (a South Africa oil producer)?
It concludes that not only is 2 stroke oil totally ineffectual for increasing diesel lubricity but that JASO FC spec 2 stroke oil will cause buildup of significant injector deposits with the expected adverse effects on performance.
BTW, I run TCW-3 at 200:1 in my TDi and will continue to do so.
Thing that stood out more for me was the "Refinery Diesel" (diesel without any additives) HFRR results which should be equivalent to the Spicer report test (allowing for variation in the base stock causing the "raw" diesel to have different baseline wear levels). There shouldn't be enough variation in the base fuel for the effect of 2 stroke oil to be so markedly different (or so I would have thought).It certainly counters the very limited and selected information available in the Spicer report. I will not question the methodology due to the cited references, but am curious as to how, on the HFRR results, the EN590 fuel with the 2SO is worse than the EN590 or 2SO individually. I would think, as shown in the Market Diesel results, that the 2SO would have some benefit, even if it's minor. This is shown in the SLBOCLE results as well, where the 2SO adds some improvement.
