Sputterputz
I have to personal cars that are diesels, my wifes 02 beetle stock as the day it came off the line, and mine 03 golf 2dr which just has RC2 and some 502s.
I replaced her pump with one off of my rebuilt shelf because it gave me a timing deviation code and the timing wouldnt stay put on the pump, I was able to read it with VAG, and it was way off, I proceeded to move it and get it situated where it was within spec but slightly advanced.
After doing so a few days later it was off again with the same code, so I pulled it, it was loud and the timing wasnt staying put so I put a rebuilt unit in that I had.
It is now running great besides a start up hiccup that it does when stone cold, but runs great, I was trying to set the timing on VAG and noticed I could see the numbers in the group 0 measuring block but when I switched to basic settings it would go to all 000s. Even when the car was warmed up it was doing that, so I took the numbers off the measuring blocks and put them on the chart manually and got it happy that way.
Car still hiccups at cold starts but runs like a sowing machine otherwise.
Both are manuals, both have 130K on them.. there is no problem with mine, it is just in the story to make sure that VAG would work on my car and it does, it shows the graph and all..
So is it a bad sensor in the pump or ?? The timing reads when it is in measuring blocks only, if you go directly to the basic settings, it will flash a number up there and then go to all 000s..
sal
sal
