Well, a quick update everyone on my progress. I have no idea how many hours I have into this project now, but it is a really large number. Since my last post I have done the following:
Extensive wiring. This includes removing all the phone and disc changer wiring that was in the C4. I went through the BOSE amplified speaker setup and realized that it is really easy to make that system a non-single-ground-wire setup... the point where the connection is made isn't far from the head unit and the car is actually not wired with it as one wire, even though the wiring diagrams don't say so. I did research online and everywhere I looked it was considered a problem that had to be accepted but it wasn't true. Hopefully this information helps someone else that deals with modding the sound with this car.
Anyway, so I soldered in the new head unit's wiring so it will all fit neatly and not have excess everywhere. Also I was able to retain the Audi handsfree microphone and rewire it to work with the head unit. Hopefully it works well. It is nice that I don't have a tacky looking mic hanging around like I've seen in many cars. My goal with this project is to keep everything very professional and factory in appearance. I removed and dismantled the BOSE rear subwoofer assembly, at this point I discovered that it truly is a two channel unit and was able to wire the head unit to support it properly. In a nut shell the whole system has it's own amps for each speaker and you only have to provide line out to each. The rear sub and rear door speakers are all fed by the same rear signal and that is totally fine with me anyway. All the wiring for the sound setup is very clean now, I hope it sounds good!
I largely dismantled the AEL engine. Swapped the crankshaft seals, camshaft seals, ultrasonically cleaned virtually every part that comes off. New timing belts, went through the power steering pump, alternator, vacuum pump, transmission slave cylinder (holy smokes was that corroded inside! This should be cleaned or thoroughly flushed every couple years IMHO). All of that stuff is back together and the engine/transmission is now bolted back together ready to be put back into the car. I bought a OEM cyclonic air/oil separator from a guy in Germany on Ebay.de (Had to use google translate to even communicate) it arrived, I threw it in the ultrasonic and it's now mounted.
Just tonight I finished mounting my Webasto diesel fired coolant heater. I'm really pleased with how that went, I used some spare line that came off the gasser A6 to run back to the tank for the dosing pump. It will be very nice to have this on the car to save the TDI from cold starts. It sure worked great on my CDI smart fortwo. The full interior is still out of the car so I can wire everything in and keep it OEM style. For example: My daytime running light circuit I added from the Canadian Spec A6, since the Diesel wiring didn't have it. Well, the diesel wiring didn't have a bunch of things so I had to make new harnesses after going through literally hundreds of wires.
Anyway, the daytime running lights put 12V through a resistance wire so the headlights (low beams) are dimmer and that is what is on when the headlights switch is either off or on parking lights. I rewired the system by taking relay sockets from the spare A6, pulling the pins from the relay sockets, color matching and using appropriate diameter wire for the relay socket, changing the circuit so the fogs get the resistance wire when daytime running lights are on, and then when actual headlights are on the fogs get the power redirected through the proper switch on the dash. This was all in effort to save my HID headlights, which I pulled from a Honda S2000. They will only be getting full 12V and this is only when the headlight switch is are actually on. Since I used an OEM relay socket, I put it in the appropriate location in the Auxiliary relay panel 1.
The Webasto heater I am installing I'm also wiring this way, using OEM fuses and relay sockets so I can put in into the OEM wiring (though a seperate harness) and have it all look factory. In the end it doesn't matter I guess, but since I have the car completely dismantled I figure if I'm doing it why not do it as good as I can right?
I did some other little adds to the wiring, added the adjustable headlight circuit, the button operated window wiper control circuit, rewired the gasser cruise control and added the necessary pins to the OEM ECU so it will all work. I just finished changing the wiring so the car will actually tilt the mirrors when I shift the manual in reverse. This was easy to do once I figured out how the Manual and Auto differ in wiring. The Auto has this circuit in the Auto transmission wiring harness, and the manual has this in the main harness. I pulled the wiring from the Auto harness and made a simple little stand alone harness for this so it would work as it should for manual trans setups.
My Curt hitch came in and I've started to mount it as well. It is ready for drilling but I'm going to wait until I'm ready for doing more undercar painting before I do so I can repaint the holes so I don't get rust from drilling through. All that being said the Curt hitch fits perfect and I had it sent with a euro style drawbar which looks much cleaner.
So here is one interesting tidbit, did you guys know that on the C4 A6 the diesel HVAC system has an electric auxiliary heater core? I'm glad I had an entire TDI car here for my swap otherwise I wouldn't have known to swap that!! I bought a new heater core online that has the proper size connections (BEHR/Hella I think) and put it in while I did the swap. The donor TDI had been in a collision and the HVAC fan housing had been broken so I needed to swap the electric core and wiring over to the Gasser HVAC unit. Other than the hole for the wiring everything else was direct simple swap.
I cannot believe how expensive that OEM 01E transmission oil was! I figured I would swap out fresh fluid since I had everything out.
I hope to be able to post in a week and tell all of you how the car is back together and running... but at this rate, it may be much longer. When it is done, it will be one awesome efficient car though.
