VW2.0TDiDriver
Hi,
I hope this is the right place to ask for some advice now as I am this close to resell my TDI that i bought just a 6 weeks ago.
Its a low milage 2009 chiptuned Golf 2.0 TDi CR CBDC engine, this car generally has been a pain in my butt since day one.
Long story short:
The day after I drove the car home after buying it (3,5hr trip) I changed the oil. Previous owner claimed to have done it recently but I always change the oil after buying a veichle anyway) This engine should have around 5L of oil, I drained just under 7L and refilled 5L fully synthetic oil. ( I did check the oil before buying the car but as the seller kept it outside, it was raining like crazy and getting dark, I probably didnt spend enough time on this.)
A few days later, the car starts smoking like crazy, dieselsmelly white/blueish smoke, the turbo starts whining from engine idle speed, and the idle speed in general is higher than normal (just above 1k RPM) This might be the cause of the high oil level, IF the seller didnt overfill it (he claimed he didnt overfill it but I dont really believe him)
Firstly I thought the smoke would be DPF regens but it kept doing it over and over again, and some days it completely stopped smoking, turbo whine was gone and idle speed was around 750-700rpm
No CEL/DPF lights..
So I started with cleaning the EGR valve and throttle body, found quite a bit carbon buildup. I also found a blocking plate between the exhaust feed line and the EGR valve. So I removed that after cleaning and put assembled it all.
The next day I went for a test drive. Everything was now back to normal, turbo whine was gone, idle speed back to normal and no smoke at all. Throttle response was a lot better too. Good stuff, I thought..
So I drove without any issues for a month and now its smoking like crazy again and all the other symptoms are back. I use the car mainly for commuting, so it usually gets time to heat up properly and very litte city driving.
Ive got one fault code which is a bad glowplug but nothing else.
Other than the engine issues, the driver door cant be opened from outside the car, a few windows dont work now and the boot has a water leak, some knocking noises from the supsension has occured etc, nothing that I cannot fix.. But I havent worked a lot on newer TDi engines like this one..
I would appreciate any help as im sick of this car now and regret selling my old Passat b6 TDI
Long story short:
No CEL/DPF lights..
