don't ask me... I'm not a tuner...
info@vanvught-tuning.nl knock yourself out...
everything about boost , duration , iq , soi has been discussed
on this forum in great length...
I just have an allergy for 'secrets'...
JW
its not a secret id just rather not say if i say something and he blows his engine it was me that said those settings
my settings are not safe and are not to be used by people who have no idea what is going on my map is setup for as much power as possible over a short period of time
if this map had to be used on a circuit for 6+ laps the engine would melt down after the second lap
but people thing they can run as much power as the engine can produce and then do a prolonged top speed run and everything be ok
depending what you use the car for and the way you drive it would depend on the kind of map you need people would say my map is retarded and not safe but for what i need and how i drive it is perfectly fine
on the ppd 170 on stock you are looking at 205-215 safe after 215bhp on stock engine the egt are over a 1000c and with a hybrid it just makes the problem even worse so i do not recommend a hybrid on the ppd 170
and i dont recommend pushing over 215 if you intend to do prolonged track sessions or top speed runs
i hope the above clears things up on why i dont want to say anything
mayb like saying i run 34 soi and then some one decides to try it and lifts the head i would rather not say for the safty of other peoples engines
but 47 deg duration and around 2.3bar should see around 260 mayb 270 bhp
then you can add more fuel and boost but you are hiting high diminishing returns were heat starts to rise very fast smoke levels rise very high and bhp may only rise by 2bhp and you gained an extra 300c egt and a lot of smoke
the question is how far do you want to push it and do you want to blow it ? me giving my settings will help no one other than some one coppy them and blow somthign up
