2.0 TDI 140 Turbo on and off boost (VW Sharan)
JimmyUK
Notts - UK
VW Sharan + (Mondeo ST)
Hey,
Hope someone here can shed some light on this weird problem I’m having with a 2006 VW Sharan 2.0 TDi 140 BHP (136K miles)
The turbo seems to cut in and out during acceleration. I’ve replaced several parts now and costs are adding up! :S
Actuator Valve (N75?)
Main vac hose pipe (7M4611931R) had a slight split in it.
2x Boost pipes (see image below)
EGR Valve
I’ve tested the actuator with a hand vac pump and it moves freely and also it holds its vacuum when left connected. I have a VAG COM and have ran the test on the Actuator Valve, the engine changes tone, so one can assume that it’s doing its job.
I’ve changed the EGR valve to a new one. This improved the performance slightly however did nothing to cure the turbo surging.
I’ve checked the intake to the turbo for excessive oil, none looks clean. The turbine also spins freely.
The car is serviced every 6000 miles (twice a year) and has been since I’ve known it from when it was a couple of years old.
I’ve checked over all the boost pipes, replaced the one just before the boost pressure sensor and then one before that that links to the intercooler (Parts 17 and 6 on the diagram below). They separated once and looked like the lugs were worn, so just changed both.
I’ve captured from the VAG COM graphs that clearly show the requested boost and the actual boost fluctuating under it. You can clearly hear the whoosh of the turbo then the release of the pressure in time with the graph. There are no fault codes on the ECU, never goes into limp mode.
GREEN = Requested Pressure
Yellow = Actual Pressure
If anyone can suggest something that maybe the issue or can point me in the right direction please do comment. If there’s any further info or data that I may have missed, again let me know.
Kind Regards,
Jimmy (UK – North Nottinghamshire)
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
Well that was over 2 years ago. Sometimes the wires to the actuator/turbo get snookered.
Steve-tdi
Birstall
2.0 tdi 140
When i unplug the sensor from throttle actuator the car seems to run better than having it pluged in. That mean the throttle actuator is knackered?
JimmyUK
Notts - UK
Hi, Didn't get it solved in the end, car developed other issues and i sold it for parts.
barlidge
Langford
2007 Sharan 2.0 140
Hi Steve, did you ever solve your issue, I've got a 2007 140 does the same thing, have replaced just about everything to no avail :cry:
BobnOH
not-a-mechanic
central Ohio
Someone expert in reading those plots in Post #1 should be able to give a clue. You can clearly see the boost actual dropping out.
