Ive got a 92 cabriolet im swapped in a 1Z, I Believe its out of a 97 passat. Ive checked the wiring multiple times, everything seems to be in place. I give it fuel out of a jug or thru stock fuel pump and regulator( for now) which is giving it to much pressure but it still wont start. It will smoke, if i crack injectors it sprays fuel. it will run on brake cleaner. ive checked the timing multiple times. has compression. Is it possible for it to be out of time enough to not start even with it pinned correctly. From what I understand if the pump has 12V and fuel it should at least run just maybe not great. Any Ideas would be appreciated, im getting pretty frustrated
