BoostedOne
Hello all!
After doing several late model gasser swaps I am working on a 1z 96 passat TDI into an early Rabbit('80) diesel for a guy. We are not converting to CE2. Being an early westy D the car doesn't have a tach, early style, nc oil pressure warning system etc.
1)For oil pressure warning I tied the blue and black wires from both together, correct?
2)VSS.. we arent going to tear up the dash for the b4 cluster. Owner for now is content to have no speedo. It appears output of vss goes to cluster then cluster sends a speed signal to the ecu. Is this the same signal thats teed in the cluster or different? Im wondering if I should tie the wire from the vss to the speed signal wire of the ecuor leave them unconnected...
3) From the diagrams G60ing posted, there is a wire that goes to pin 26 on the cluster from pin 9 on the ecu. Its labeled "injection signal t1". What is this for? Does it need to connect to anything?
4) the ecu gets a signal from the brake lights to pin 44.. again any need to connect that?
5) finally, what do I do with the clutch and brake switches in the engine harness if cruise control isnt needed? I think I read leaving them unconnected the ecu will have codes or limp mode?
Thanks for the help!!!
