twentyeight
So I'm rebuilding a 1Z with new .5mm over ALH pistons. Initial piston protrusion was about 0.030" which is well under the minimum spec. So I had the block decked 0.007" to hopefully hit right about the middle of a one-hole head gasket.
Unfortunately I got the block back today and the measurements don't look good.
They're listed here: in slightly prettier form, but from #1 to #4: 0.035, 0.036, 0.043 0.047. On all pistons, the pulley side measures lower than the other side—*#4 measures somewhere about 0.052".
I haven't gone back to the shop yet because I don't know what to ask for. If the deck has to be cut again flat, 0.052" is over spec for a 3-hole gasket. My first plan is to take it somewhere else that can measure piston protrusion more accurately before I disassemble it again and take it back.
Does this look usable still?
