markd89
We followed the steps in this thread http://forums.tdiclub.com/showthread.php?t=287336
After re-assembling the pump, and priming with mity-vac and lots of fruitless cranking, we are getting a dribble at best at the injectors.
I checked and there is no +12 volts at the fuel cutoff solenoid during cranking. I think that's a clue.
I checked for codes and there were none.
We put a jumper on the solenoid to supply the 12 volts and there seems to be a little fuel coming out at the injector junctions but not the gushes I would have thought of. I also have error codes now, but I think those are caused by the fuel solenoid jumper wire.
So questions...
1. With the injector lines cracked and the engine cranking, am I right to expect righteous squirting of fuel or would a dribble be normal?
2. Any suggestions on what I have screwed up putting things back together to have these symptoms? (i.e. no 12 volts at the solenoid)
I'm quite confident that everything was done according to the video instructions with the one exception of the QA nub into the collar. As the video says, you can see it going in up until the last moment. I don't think that would cause this symptom, but maybe?
I appreciate any help.
Thanks!
Mark
So questions...
Thanks!
Mark
