phazersonstun
Hello!
First off I would like to commend you guys on your well run forum! This is my first thread post!
I have a 1986 Golf Diesel with a 1.6 N/A motor:
I have quickly gotten over the 52 horsepower... And the bolwn headgasket that I just got.
So I found this:
It's a 1Z motor from a 1997 Passat, with the 5 speed manual.
I know that I need a pedal cluster and a main wiring harness. And also convert from the linkage shift to cable shift. But I am wondering if I have to convert to CE2?
I think that most of my motor mounts will work, except maybe the front one.
Other than that I should be able to drop it in, right?
Maybe you guys know where I could pick some of this stuff up at, or what else I need in order to make this swap the best that it can be. I have already upgraded my suspension. Bilstein PSS coil-overs, Corrado suspension, brakes, and rims! It's pretty sweet! So all that it needs is a bit more poop! Thanks!
So I found this:
