Digital Corpus
Outputs are at the bottom of each sheet. I stuck with LibreOffice for the work since the current Office 2016 doesn't import CSV files.
Engine parameters:
Testing methodology:
The latter was utilized because the MSA15.5's software for a GH ECU doesn't like trying to idle over 2200 RPM. Due to human error and other physics, some continual adjustment was made using process 2 as RPM was difficult to settle. I removed 1 or 2 chunks of data that didn't average out over time along with the rest of the dataset for that RPM range if there was more than +/- 150 RPM fluctuations. I give a confidence of +/- 2% (so a score of 80% means 78%-82%) due to this, which seems reasonable.
Ice packs were used to cool down the fuel pump.
A minimum of 300 samples per RPM were utilized and averaged for the computations.
Current temperature and weather were pulled from observable history and linearly interpolated within reason for ambient air conditions.
Calculation order of operations:
I used my handy graphing calculator, TI's Voyage 200, to handle the computation of density and RH % adjustments and [automated] unit conversions to reduce human error.
The following graph pulls the data from the aforementioned process and plots it from 900 RPM to 4500 RPM.
Data available here
Numbers for the TL;DL
Graph for the visual
Please feel free to check my work. Additional details available upon request. I do plan on doing this with the Colt Stage II camshaft in the near (1 or 2 months out at best) future.
Engine parameters:
- Stock camshaft
- PD130 Intake manifold
- Mildly ported head
- AFN exhaust manifold
- GTB1756VK turbo port matched to AFN manifold and adapter
- 2 feet of 2.5" downpipe with tapered-to-match hotside
- For RPMs 900 to 2000 I used the ECU to ramp idle from 900 RPM to XXXX RPM as the engine warmed from 80 °C to 85 °C. Intervals of 250 RPM used
- For RPMs 2250 to 4500 I use a 1" diameter wood pole, a dictionary, and driver's seat to hold the throttle at an appropriate point for the desired RPM. The engine was at least 85 °C before logging commenced and once at 250 RPM, intervals of 500 RPM were used.
- Determine current air density and factor in relative humidity.
- Determine 1 cylinder's mass of air when completely full with current density.
- Using barometer, MAP Actual, ambient air temp, and IAT, determine new RH % under compressed state.
- Determine post charge cooler air density from MAP Actual, IAT, & RH %.
- Determine 1 cylinder's mass of air under these new conditions.
- Divide MAF Actual by previous result to compute volumetric efficiency.
Data available here
Code:
RPM 900 1000 1250 1500 1750 2000 2250 2500 3000 3500 4000 4500
VE 86.9 87.2 88.6 90.8 92 90 88.6 86.8 84.7 82 80.1 74.4
