1Z/AHU into 78 Bus
markd89
Los Angeles
1978 VW Bus 1Z TDI
INTRO:
I'm hoping this will get to be a nice long thread with some good pictures. I have finally decided to do this conversion. My old engine is dead. Emissions here in California tell me if I get a 1997 or earlier engine I will be exempted. TDI is the ideal powerplant for power and economy.
I'm going to have the help of my long-time mechanic to get this done. I'll do some work and get his help too. Although I'll get a great deal on his help, I'll still be paying for it, so it's extra important that I plan this well and make the right design decisions. I want to make this as simple as is possible.
My bus currently has a 2.0l and a 6 rib trans. It has the small engine access hatch typical for Type 4 buses. I plan on a 1Z/AHU (the only TDIs sold in the USA prior to 1998), a re-geared Transaxle and cooling underneath. I want to be able to go up a hill at 75 mph and get close to 30 MPG if I drive nicely. Let's see how close I can get!
GETTING STARTED:
I have a lot more ideas and questions, but to start with:
1. Angle. I know 50* is possible through Kennedy or the Vanagon diesel bellhousing. I read somewhere (but am not sure) that 15* will also work and if I did that I would not need to switch out oilpan and oilpump. Will I be OK on fitment issues at 15*? Any reasons not to do 15*?
2. Fitment of engine against fuel tank. Paulie used an ALH engine and had the the vacuum pump and coolant flange hit the tank. His solution is here http://viewfromabus.blogspot.com/2009/09/fuel-tank-solved.html and I'd like to avoid it. On 13 Window Deluxe's bus http://i52.photobucket.com/albums/g5/angryvanagon/Baytdienginecomplete.jpg, I don't seem to see those protuberances. If I stick with 1Z/AHU are these a non-issue?
3. The hole. My bus already has an access hatch for the Type4 engine. I want to be able to do the install and engine maintenance going forward without removing the engine. Can I do that with the Type4 hatch or do I really need to cut a bigger hole back there.
Thanks in advance!
Mark
markd89
Los Angeles
1978 VW Bus 1Z TDI
Project progress:
Decided on 15 degree mounting.
Decided on using the stock engine hatch - no additional cutting.
I ordered up the kit from Kennedy including the Stage 1 Pressure plate and stock clutch disc. This is supposed to be good to 225 pound/ft torque.
I'm using the 90hp AHU engine. I may do the mods to take it to 110hp, but even so I should be under 225 pound/ft.
Mark
G60ING
Alexandria, VA
I don't know the bus's clutches but I know the TDI engines are easy to get above the 225tq level, get the uprated clutch.
markward
Loxahatchee, Florida
82 Vanagon and 2011 JSW
That is going to depend on the hill, the hp/torque and the gearing you end up with. To get the mileage you want i.e. 30 mpg, you will need to gear tall. When you gear tall, you may be too tall for long uphill grinds even on the interstate. It that case, you will need to use 3rd gear and I don't believe the math will let you run 75mph in 3rd. For numbers to crunch. Stock max torque is around 2200 rpm, max hp around 3800rpm. You can upgrade the power, but may affect mileage and reliability. Should be a nice ride even if you don't hit your targets. My vanagon with a 4.14 ring and pinion and a taller .77 4th gear runs about 2900 rpm at 70mph. Good luck and post lots of pictures.
markd89
Los Angeles
1978 VW Bus 1Z TDI
Thanks for the help. I emailed KEP and changed from Stage 1 to Stage 2 on the pressure plate. The cost is the same, just slightly more left leg workout, which is fine.
Thanks for the ideas. I had been thinking about that as the trans is one of the next things on the shopping list to get ready. I do agree that in order to hit minimum RPMs in 4th that there'll likely be big hills that require a down-shift to 3rd. That's probably OK as most of the hills I do are in-town and not on the freeway.
Are you able to climb hills in 4th gear at 2900 rpm?
Is the 4.14 a special differential?
I'll also post up the gear ratios I come up with for your review.
..and I will be posting pics!! :D
Thanks again,
Mark
markd89
Los Angeles
1978 VW Bus 1Z TDI
So news, my parts car is on the way to me and I'll have it in a few days!
More planning:
I probably don't care about using cruise contol. I'd also prefer not to get any CELs. Do I still need to deal with the VSS? If so, what's the easiest way to do that? Can it be de-programmed from the software or do I lose some engine efficiency or performance without it?
Thanks,
Mark
markward
The earlier TDI engine may be different, but I did not have a VSS when I first got my Vanagon running. It would not trip the check engine light and ran fine. There were faults recorded, but I have since learned that not all faults will turn on the CEL, some are just recorded. When I installed the VSS, the engine actually developed an SDS problem it did not have before that I needed to resolve. So you should be fine without the VSS. Label the wire in case you want to add cruise at a later date.
markd89
Los Angeles
1978 VW Bus 1Z TDI
More news/questions..
Engine mounts:
I found VW Part# 1H0 199 262L inexpensive on eb*y
and I think these look like a good solution. I'd just bolt one on each side between the support bar and the mount I get welded which attaches to the engine.
Transaxle:
I'll be using a 091 with a 4.57 differential. I wish there was a way to get a 3.x differential, but there's not, so I plan to reduce my RPMs by using lower gears for 1-4.
Ffor economy, I can up-shift at about 3000 rpm which puts me at about 2000 rpm in the next higher gear. If I want to go faster or deal with a hill, I'll just shift higher than 2000rpm.
So far, I'm thinking about a 1.14 3rd gear and a 0.70 4th gear. These seem to be the lowest ratios available and are commonly used with Vanagon TDI conversions so figure they should be close enough for my bus. I will be at approximately 2700rpm and 65 mph in 4th gear. If I come to a severe hill, then I can downshift to 3rd and go 4000 rpm and 62 mph.
For 1st, I'm thinking about 2.9 and 2nd 1.7. These are also the lowest I've found. I can run 1st gear up to 18mph at 3000rpm, then shift to 2nd and be at 1800 rpm. If I run 2nd up to 3000rpm, I'll be at 31 mph.
Here's the gearing spreadsheet I used. The yellow cells are economy driving. The orange cells are spirited driving ;-)
My engine should be about 100-110hp tuned. Do you see any issues?
AndyBees
Southeast Kentucky
I went with the 1.14:1 ratio 3rd and 0.77:1 4th ratio using the 4.57 ring and pinion. The numbers looked good for the RPM/Speed running at 65 to 70 with the 14 inch OEM wheels. 15 inch wheels will drop the RPMs about 150.
As I recall, using GPS, ScanGauge, and my 2000 Jetta TDI instrumentation, driving the Jetta in 4th gear is similar to the gear ratio for the Vanagon tranny set-up I've put together. Seems it was about 2850 rpms at 65 mph......don't hold me to those numbers. But, anyway, the engine seemed happy at that RPM in the Jetta. Of course the Vanagon will be a little heavier and far less aerodynamic.
So, when I get it on the road (hopefully by summer), tire adjustment may be one thing I do.
I don't think you will need to modify the engine access to do maintenance. Once you get 'er going......... your talking air filter 20k miles, fuel filter 20k miles, oil filter 10k miles and that's about it!
A couple years ago, I saw a '76 Bay with a Subie engine conversion. The guy put the Radiator in the rear with hydraulics to raise and close the back access door......... Door opened when Rad fan kicked on.......pretty neat.
The stock EFI 2.0L should be able to do that, except on some really steep hills or with a lot of loads. Both my '79 and my '82 can. It won't ever get near 30 MPG though.
Keep in mind the T2 really was never intended to go that fast (the factory maximum cruising speed for the Type-4 powered T2 was 70, and that is really only safe with little to no cross winds). The T3 is MUCH more stable at speed, thanks to its nearly 50/50 front/rear weight bias, and despite being larger they are more aerodynamic. But even then, 75 or so is the very upper safe limit I would ever recommend driving one, and again not on a windy day.
Both the T2 and T3 were sold with a base 50hp 1.6L air-cooled engine in other markets, even when we got the Type 4 engines as standard, obviously the basic design did not have super high-speed in mind.
I've seen radiators mounted midship on the T2, with several cooling fans, that seemed to work OK. The Jeep Cherokee 4.0L radiator, two mounted next to one another longways, will fit between the unibody rails after you remove the heater duct (which is not needed anymore anyways).
The water-cooled T3 rear heater box, which is a nice standalone unit complete with blower, valve, core, etc. can be made to mount under the T2's rearmost seat, as well as up under the passenger side of the dashboard. One neat trick I saw for heat was a guy mounted the heater box under the front, just behind the front beam, and ducted it into the existing heater duct going forward to the dash. Then he simply shortened the original cable that went all the way back to the heater boxes on the air cooled engine to go to the heater valve on the heater box. That way, all the heating, defrost, and ventilation controls were just the same as the stock T2 was. Pretty slick.
In the T2, you have the advantage of having the upper bellhouse mounts, something the T3 does not have, which is nice as the engine cannot move around as much, but it does seem to transmit a little more NVH into the interior with the diesels.
markd89
Los Angeles
1978 VW Bus 1Z TDI
I agree. I plan to keep it about 70mph anyway as it does tend to get hairy going faster than that. I just want to build the capability to go faster so I could go faster occasionally and so I'm not winding it out too much in normal driving.
Being in L.A., for the time being,there is not much opportunity to go faster unless it's 4am ;-)
Thanks, that's useful too. I need to think about whether I need ducting to create a high pressure area above the radiator or whether I'll have sufficient cooling without it.
The idea being that when not moving, the fans provide enough cooling. When moving at highway speed we want to create air moving through the radiator. The duct creates a higher pressure area above the radiator and forces air down through it.
Here's a pic of what someone else made:
I'm glad you brought that up. My current plan is to not use the bellhouse mounts. I've been talking to "13 Window Deluxe" who built this bus. He said there would be too much vibration transmitted into the bus using the bellhousing mounts. He said that using two nice hydraulic mounts on a custom crossbar and the stock front mount I would be good. It does make me a little nervous that there's not more support in front and the T2 has a smaller front trans mount than the Vanagon, but he says it worked well for him. What do you think?
Thanks,
Mark
It will probably be fine, if the two rear mounts are spaced out a bit. The T3 got away with what seemed like minimal mounting largely because the boxer engines have very little NVH as opposed to an inline 4 cylinder (this is why boxers can run just fine with NO balancers, and many inline 4s have to be equipped with dual balance shafts). A diesel inline 4 will obviously work the mounts even more.
Interesting someone else decided to ditch the upper bellhouse bolts on a T2 conversion, as I too was wondering about that. Thanks for the link!
Keep in mind, though, he used a standard T3 diesel bellhouse, that lays the engine down at a 40 degree angle. I would bet that Bus is not too terribly smooth and quiet.
markd89
Los Angeles
1978 VW Bus 1Z TDI
Oilhammer, thanks for your comments :)
Next up:
Cooling:
I looked for a radiator which can go lengthwise under the bus and have the in and out connections at the rear. Most radiators have the in and out connections diagonal from each other.
I found these two radiators which look interesting:
http://www.kmjent.com/cart/home.php?cat=5
They claim that these will cool 500 hp. I know I'll lose efficiency because the radiator is not sitting at the front. I also know that the TDI creates less waste-heat than a comparable gasser. I'm hypothesizing these radiators should be enough.
My plan is to lay the radiator at a slight angle up to the rear so that air bubbles will rise through the hoses. It will have a temperature controlled 12" fan on top blowing down. I'll run 90 degree elbows to get the water moving towards the back of the bus rather than straight up.
The radiator will be boxed in at the sides and at the top to make a scoop effect. The total height will be about 8" which should be no lower than some of the suspension parts. I plan to run a mesh in front to keep the large detritus from getting blown in there.
I am clearly not an artist, but this should give an idea.. What do you think?
[/img]
markd89
Los Angeles
1978 VW Bus 1Z TDI
I *think* I have figured out how the two types of mounts work. Please comment and let me know what I'm missing!
Mount#1 - aka Rabbitboy style is shown below. This mount is squished between the metal mounts attached to the engine and the engine support bar. It is bolted to the engine mounting using a single large bolt on top (A). It is bolted to the engine support bar with two bolts at the bottom (B).
As the engine moves, the mount will be squished further or pulled apart.
Mount#2 - aka 13 window deluxe style is shown below. This mount I found harder to understand. I think that's because I can't see how it connects to the engine support bar.
I believe the center bolt runs through the rubber mount, and then bolts on the bottom to a plate welded to the engine support bar. Did I get it right?
This mount seems like it works by being squished and stretched?
Thanks,
Mark
markward
The mount in the second picture reminds me of the early Porsche 911 setup. They used that type of mount and connection to the body on both sides of the engine compartment. Your understanding of the function is correct.
markd89
Los Angeles
1978 VW Bus 1Z TDI
I'm examining the 1997 Passat 1Z donor which I've been driving around for the last couple of weeks and have questions on fitment.
1. Intake fitment. The intake protrudes upward higher than the valve cover. I'm thinking this may be an issue with my 15* setup. Is there another intake I should look for or do I have to make something custom?
2. Exhaust Manifold/Turbo. I'm not anticipating fitment issues here. Should I be?
3. Belts: Power Steering and AC. The donor car has PS and AC. The converted bus will have neither, but I like the idea of the AC compressor, that perhaps I will hook it up later. My plan would be to leave the AC compressor connected via the belt and block off the hoses in and out. If I'm seeing things correctly, the PS pump appears to be driven by a separate V-Belt, so I should be able to just remove that without screwing up the serpentine arrangement. Does that make sense?
Thanks,
Mark
annieneff
Seattle
1983.5 Westfalia tdi (afn), with flipped 5 speed V6 (dvz) transmission
Just wanted to give you a bump of support, and let you know I'll be watching intently. I hope you get done by this July so when I start mine I can follow in your footsteps! Beautiful idea (many of us have had it), way to pioneer the way for the rest of us--
Andrew
markd89
Los Angeles
1978 VW Bus 1Z TDI
Andrew, thanks for the encouragement. It does seem daunting sometimes. I'm not exactly the pioneer, though, there are at least 3 TDI buses that I have discovered and I'm trying to copy as much of them as I can ;)
Latest question... One of the UK guys says that the Passat 1Z is supposed to be mounted at 30 degrees and by me mounting it at 15 degrees in the bus that I may have oil-pickup issues. He suggests a Golf TDI pan and oil pickup. Thoughts?
markd89
Los Angeles
1978 VW Bus 1Z TDI
All FWD VAG products with inline engines mount their engines at 15 degrees, been that way since 1974.
Thanks Oilhammer! I'm not an expert, but I had never heard of 30 degree mounting..
Mark
P.S. I got some gifts in the mail from Kennedy today. I'll post up some pics soon.
markd89
Los Angeles
1978 VW Bus 1Z TDI
Looking for tips on waterpump (aka power steering delete)
I'd appreciate any advice on this:
One V-belt drives the power steering and water pump and the belt is tensioned by moving the power steering pump.
I won't need the PS pump on the conversion but I still need the water pump.
I'd like to just remove the PS pump, but then I lose the ability to tension the belt for the waterpump . I can't just leave the pump in there but not hooked up. Maybe I could connect the inlet to the outlet of the pump and leave it hooked up?
Am I missing an easier answer?
Thanks,
Mark
markd89
Los Angeles
1978 VW Bus 1Z TDI
I found the answer on the Yahoo Groups Vanagon TDI list. There's two solutions.
1. No AC/No PS. You can run a serpentine setup which runs the water pump.
2. AC/No PS (my situation). You can run the following:
Conveniently enough, the water pump pulley from a 1.6TD Quantum or Audi (longitudinal 15° install) is the correct offset (when flipped around) and is the split pulley design with adjustment shims between the halves so adjusting the belt is taken care of. Couple it with a 10 x 650 v-belt and the A/C serpentine belt and you're done. The pulley is part number 068121029A. The adjustment shims are part number 068121185B. I believe both are still available new from VW. The pulley should be around $55 and the shims $1.50. You'll need 5 or six shims.
VBelt Looks like vanagon diesel water pump belt. 1981-1988 VW# 068121039B
I'm ordering up parts next week -- EGT gauge (getting Dakota Digital w/ 20 foot sender wire) and the various parts to do the exhaust manifold, intake manifold, timing belt and serpentine belt (incl harmonic balancer and waterpump). I'm planning to get that all done in the Passat and sorted then pull the engine for the swap.
markd89
Los Angeles
1978 VW Bus 1Z TDI
Timing belt - without crank TDC?
In order to properly do the TB procedure, a check of crank TDC is required. In the donor car, this is done easily enough by looking at the flywheel.
It occurred to me that I should be planning how to achieve the same thing in the conversion car with the new flywheel and different transmission. Here's what I came up with. If you have a better or easier method, please let me know!
a. Move engine to TDC using CAM and original flywheel marking before removal of engine from donor car.
b. With engine removed, mark a location on the engine where the flywheel marking lines up.
c. Put the new flywheel (but don't tighten so as not to move the crank position)
d. Mark the flywheel where the mark from the engine lines up.
e. Without moving the engine, find (or cut) an access hole in the bellhousing to see the flywheel.
f. Mark the accesshole and flywheel so that they can be lined up in the future.
markd89
Los Angeles
1978 VW Bus 1Z TDI
Again, an easier solution has cropped up courtesy of rabbitboy in the UK:
Hi Mark. The kennedy flywheel comes with a drilling in it that lines up with a hole in the conversion plate behind a small steel plug that pulls out. With the cam cover removed and a 4mm thick plate locked into the rear of the camshaft against the top of the head, this hole in the adaptor plate should line up with the drilling in the flywheel and you are now at tdc.
markd89
Los Angeles
1978 VW Bus 1Z TDI
My plan has been to get everything as prepped as possible so that the swap itself is quick..
So far, in the donor car - I have a new timing belt and associated parts, new Bosio 1019 Nozzles from Kerma and have fixed a few misc. issues - coolant leak, dirty MAF, etc. The donor car is running nicely. If it wasn't rusty, I'd feel bad about what's going to happen to it soon ;)
My thread needs more pics and so I wanted to share my new heater flange which I had made by Jeff at metalmetalmetal.com - this is CNC'd out of a single piece of aluminum and will hopefully give me enough clearance to not hit the fuel tank. Jeff expressed an interest in knocking out more of these if they'd be useful to our group. Price would depend on quantity but the design is already paid for now.
I'll be routing up to the EGR cooler as I'm keeping all emissions stuff.
I decided to install a VDO temp sensor in the new flange, which you'll see in the pics.
I do (eventually) plan to re-incorporate the coolant glow plugs. I have two stock heater flanges and my plan is to bolt them together face to face so that I have six heater glow plugs.
I'll be installing this flange on the Passat this week to check for any leaks or unforeseen issues so that when the engine goes in the bus, this will not have to be debugged.
And now the pics..
Reddok
Hamilton, Ontario
'00 Jetta TDI 01M, '02 Jeep Liberty Renegade ALH TDI swap
Mark, did you decide what mounts you are going to use yet? I have one of the 1H0 199 262L on my passengers side in my Jeep conversion - it really cut down vibration over the non-hydraulic version. I'm debating on using one on my drivers side as well, but I don't know if the pass side mount will function properly on the drivers side as that mount is pulled apart under load rather than squished together like the pass side 1H0 199 262L would be. I may try and use the factory drivers side mount but it's quite large compared to the pass side mount.
markd89
Los Angeles
1978 VW Bus 1Z TDI
Hi Reddok,
I'm still not sure. I do want to use hydromounts where possible. You make a good point about pulling on a mount that was designed to be pushed. I was figuring that it wouldn't matter since the mount is continuously being pushed-pulled as the engine moves back and forth, but you're right, there's much greater force pushing (or pulling) on one side versus the other.
I'm hoping to pull the engine from the Passat next week and get a better look at the stock mounting and then see if it can be re-used. I believe the "front" mount is hydro and one of the rear mounts (trans mount?) is hydro also?
Mark
Reddok
Hamilton, Ontario
The front mount is regular rubber and the rear is hydraulic I think. Not sure about the trans mount.
I thought about using 2 hydro mounts, but there must be a reason VW didn't do that from the factory...
markd89
Los Angeles
1978 VW Bus 1Z TDI
Amen. I think that's really what's prompting me to just try to use the factory pieces and see what happens. If it vibrates too much, I can always set the idle to 1100 rpm ;)
