Where's theoil
I got the engine to turn both ways. At first it wouldn't go, I used a cheater pipe but now it turns free both ways. I think a chunk of belt got lodged in between the belt and a pulley locking things up. So I don't think it has a bad valve. I don't know where all the oil went, the dipstick now shows none, maybe front seal or rear seal.
If the seal in the turbo went bad it could dump it into the boost tube to the intercooler. (turbo's shot)
It would get pushed into the engine and if enough gets in a cylinder it locks the engine from turning forward.
The intercooler full of oil usually confirms the turbo seal.
I would not just put a belt on until I know why it shredded the way your did.
Bad roller or tensioner in there maybe.
You will need the specialty tools to change the belt.
There's a lock pin for the injector pump.
Another lock for the camshaft.
Tool for turning the belt tensioner.
Few other tools also to make it easier.
If you took the head off to look at the pistons you would see if there's a valve imprint on the top of the piston.
You would need the gaskets seals and head bolts at this point.
(Starting to get into $ if it did hit)
Rich W.
