RhysOnArrakis
- Joined
- Apr 15, 2019
- Location
- Lake Ariel, PA
- TDI
- 2015 Golf Sportwagen TDI SEL, with DSG, 160,000 miles
Hello, I am hoping to get a few good opinions here on this issue that I am having. Engine will idle fine, then will act as tho misfiring for about 5 seconds, then resume normal idle. This cycle repeats anywhere from every 10 seconds to every 30 seconds, no matter if the engine is cold or warm, after a drive or initial start-up. Above idle all is normal, runs very strong. It's been doing this for a few months now, and as this is not my daily I planned to troubleshoot this time permitting. But I have no failures or DTC's per VCDS, and even a tick above idle and the problem goes away! So far the most likely culprit in my limited TDI experience is a sticking fuel injector. Any other input would be greatly appreciated. 269,000 miles, fresh EGR overhaul and intake cleaning, ALL vacuum lines replaced, all regular servicing done religiously. Thanks!
Rhys L.
Rhys L.
