PradoTDI
Hi all, new here! I have a 1997 Jetta AHU with around 195k miles on it. I have an odd problem with the glow system or coolant temperature sensor. Under normal conditions the engine refuses to cold start (even on hot summer days), it just stutters and puffs huge clouds of white smoke. However, if the coolant temperature sensor is unplugged, it starts just fine.
No matter how cold it is outside, the glow plug light never cycles for more than a half second on startup, but if the coolant temp sensor is unplugged it cycles for the maximum time. I usually let it cycle for a couple of seconds before starting. The ECU doesn't throw any codes except when I unplug the sensor, and then it's just for the temp sensor. I have tried swapping the coolant temperature sensor from another '97 AHU with no change in symptoms.
Any thoughts on what it could be? I have had it plugged in to my VCDS to check for codes and see if there are any issues it shows at startup, but to be honest I don't really know what to look for; I've mostly worked with old mechanical diesels.
