markd89
I'm running the 1Z engine from a 1997 Passat TDI in my conversion. Oil consumption is high at about 1 quart per edit:500 miles or so. The engine has < 200K miles and has been running Rotella T6 5-40. For now, I just add oil at each fillup but I'd like some ideas on causes/solutions.
Since the engine is not in a Passat anymore, I'll list the changes from stock and other factors that might be useful:
1. Home made PCV filter/catch can. PCV gasses run into a 1/2 gallon bottle to filter them before being returned to the intake as stock. Oil does collect in this but nowhere near the same amount as is being used.
2. Disabled EGR.
3. Malone tune appx 1.5. DLC1019 injectors. Air-water intercoolers.
4. Stock turbo. The outlet is wet with oil, but there is no big pool of oil in the intercooler.
5. Highway 10 psi boost typical. Max for the tune is 16 psi.
6. Highway RPMs are 3000-3300 typically, which is more than a Passat would do in 5th gear unless you were going really fast.
7. For most of the 50K miles on the swap I have been running an additive of 2 stroke oil + Power Service. I recently switched to just Power Service because I was thinking maybe the 2 stroke oil residue was perhaps affecting the rings. After doing this, I see no change in oil consumption but the oil seems to be a little clearer.
8. Hot oil pressure
1000 rpm (this is my idle speed) appx 12-15 psi
2000 rpm 30 psi
2500 rpm 40 psi
3000 rpm 50 psi
So my questions:
What is typical to cause oil consumption in a 200K mile 1Z?
Any clues on my consumption based on the data above?
If I want to put off a repair, would using a heavier oil, i.e. 10w-50 slow consumption? Recommendations?
Thanks much!
Mark
2. Disabled EGR.
8. Hot oil pressure
2000 rpm 30 psi
2500 rpm 40 psi
3000 rpm 50 psi
So my questions:
Thanks much!
Mark
