otty
- Joined
- Nov 7, 2010
- Location
- Revelstoke, BC
- TDI
- 2003 Passat W8=>TDI swap, 4Motion Wagon, PD130(AVF) 6Speed Manual, 2006 Jetta MKIV PD(BEW) Wagon 5Speed Manual
Hi Guys,
My brother has a 1996 Jetta with the AAZ engine. His injection pump is leaking and he is told by his mechanic it needs a rebuild/reseal. My question is are new pumps still available? Does this engine share the same pump as the more common AHU or 1Z engines? Any recommended rebuild shops in Canada ideally? One shop that has been recommended is http://performancediesel.ca/index.htm
His mechanic wants to send it to a place in Calgary for a rebuild and I worry about their familiarity with VW pumps.
Thanks for any input.
