Big Daddy Roth
- Joined
- Dec 5, 2012
- Location
- Victoria BC
- TDI
- 1992 B3 Syncro 1Z, 1992 B3 Syncro AAZ, 1992 B3 Syncro AAA
It's currently registered as a BC vehicle. Offered for sale in "as is, where is" condition
This car needs a headgasket replacement. I suspect I overboosted it. White smoke out the back and making pressure in cooling system.
I built this car in BC and brought it with me when I relocated here back in Ontario.
1.9 TD (not TDI)
10000Kms on completely rebuilt engine (oil pan to valve cover)
Rebuilt Giles high performance injector pump
New Holset HE200WG turbo (Cummins 4BT)
Manual boost controler
Giles performance ground camshaft
Rebuilt Injectors
Custom SS 2.5" straight pipe exhaust
G60 intercooler
Digital boost and EGT gauges
Larger VR6 radiator
New starter, battery and 120A Alt
Freshly rebuilt CTN O2A transmission
Newer Stage 2 SBC clutch and flywheel
VR6 front sub-frame and rear beam (5x100 wheels and bigger brakes)
Newer brakes front and back
Newer upgraded rear calipers
Newer ball joints
Raceland coilovers (stock suspension available)
Whiteline control arm bushings
Clean black leather interior
Everything electrical works as it should.
OEM alarm / keyless entry
European E-code glass headlights
European smoked taillights
Blaupunkt bluetooth stereo
Small receiver hitch
Heater core recently replaced so A/C needs to be recharged (works well)
Clear coat is peeling on roof and hood. A few rust spots (Drivers 'A' pillar, RR wheel arch) BC rust, not Ontario cancer.
$2000 "as is, where is" condition. Serious inquires only.
1.9 TD (not TDI)
Rebuilt Injectors
G60 intercooler
Larger VR6 radiator
Newer ball joints
