If the lines are properly sized and sealed, no fuel pump is needed for an ALH.
But a good fuel pump can prevent many issues, especially in a high output diesel.
I am not sure that I would consider a 2 lpm pump adequate for full performance. Check to see if the inlet line of your Injection pump goes to a vacuum at full throttle, full rpm. If it goes to more than 4" hg vacuum, I would put a larger flowrate pump on it. If the pump suction goes to more than 8" vacuum, you might be better off with a large open line than with an undersized pump.
I have seen other system designs that use a small pump for priming and low rpm operation, with a large fuel line in parallel with a check valve in it. When more flow is demanded than the pump can supply, the check valve opens and the pump vacuum drags what it needs.
I do not know the flow that an ALH IP has under full rpm full throttle conditions. Does anyone else?
People interested in optimum performance use a lift pump that maintains a positive pressure to the IP at all times, under all conditions. This ensures no vapor bubbles or air entrainment that can limit performance.
