archemitis
I have a 1992 4x4 4runner (that i've had since 98) and want to put an ALH stage with a stage 4 tune in it. I know at one time you had to swap to the 4 cylinders w56 transmission but it looks like there are a couple companies that are making adapters for the 3vze v6 5 speed transmission. Is there a general consensus about which one is best? This one looks pretty good https://www.doomsdaydiesel.net/product-page/vw-1-9-tdi-to-3vze-r150-adapter-kit but Im wondering if the starter will get in the way. Im going to run a vnt 17 turbo, so the clearance will be a little closer than the stock one. Im pretty sure Im going to block off the vacuum pump and run an electric one from Jegs or a cummins, thats gotta be common by now right?. Leave the driveline in the stock location. I have a 9 1/4 inch Centerforce clutch rated at 309 ft lbs. Build some motor mounts... run some 33s to get the RPMs down... Anything Im not thinking about?
