I just realized the rad hoses for a 1z/aaz b3/b4 should be on the other side.
It looks to me you have the 'deeper' lower rad support. You need a AAZ/VR6 rad. The G60 rad is smaller and needs the 'higher' lower rad support.
If you use a B3 AAZ/vr6 rad, you need aaz B3 hoses. If you use the B4 AAZ/vr6 rad, you need B4 hoses. (The lower rad hose fitting is the difference here).
You can use a B4 1Z rad, but you will need the lower rad support for it.
16V radiator will not work with anything that has a serp belt. The AC compressor is in a different position on a V-belt 16V, which allows for the 16V hose to go where it needs to go.
Upon closer inspection, I think you have the right front mount set-up.
