Some of the other odds and ends:
Here are the tires i chose to run:
They are actually retreads from a company called TreadWright. They were about $125 a corner shipped. I got the ones with crushed walnut shell in the tire compound, apparently it makes a difference on ice. I think it is $10 less per tire for a regular rubber compound. They say they are supposed to be 31x10.5x15 but they actually measure closer to 32.5" in real life. I have yet to drive on them, but they sure look good. TreadWright was awesome to deal with and for the money, i don't think they can be beat.
The intercooler i got off ebay has worked out great. I had to trim one mounting tab on the grill and then it went together as stock. Looking straight on you can't even see that it is there.
The egt/boost gauge from auber instruments has worked out very nicely as well. My truck never had AC, so i made a spot for it where the AC buttons would usually go. I had to carve into the dash support a little bit but it fits nicely now.
I have yet to hook up the boost function for it. It is designed to work with a MAP sensor, i was debating trying to hook into the one on the ECU. I decided to just buy another MAP sensor rather than risk frying things. I put the thermocouple in the adapter i made to go from the manifold to the turbo and used the auber thermocouple. It reacts instantly and seems to be accurate. The most i could get it to read with my foot to the floor on a hill was 1200 F. The engine is stock other than the turbo though so we will see...
I was planning on somehow using a VW airbox and stock air filter. This did not work at all, i tried a couple of the more common ones and the shape was all wrong. I ended up using a rubber elbow from the Toyota 22re to go between the turbo and MAF as it fit perfectly. I scored a freebie cone filter that will have to do for now. Other than the random wires and fuel lines it looks pretty good.
That is pretty much all for now. I bought another set of injectors to put big nozzles in because i was getting a dreaded needle lift fault, they are being pop tested and hopefully i will have them back for the weekend. Once they are installed and all is good, i will order the chip from Mark at Malone Tuning. I went for a fairly long drive tonight and so far everything seems good. The vibration is minimal and only ever at idle and the exhaust is much better now that there is a muffler in it. Other than being pretty slow, it is awesome. I am sure it will be even better with the new tires and performance upgrades. Please feel free to ask any questions or make suggestions.
Luke
