The rack on the B2/B3 cars is similarly placed when comparing it to the B5, the differences are the rack is mounted to the firewall about midway down, whereas the B5 the rack is mounted under the water box up higher. The engine can only be moved a couple inches farther back until the rack becomes an issue.where is the steering rack on yours? On the A4's it sit about mid height of the engine, about 4" back. I was very tempted to run front engine/RWD only but I would of wanted to move motor back a good 8"+. There is lots of room back there...if it wern't for the rack... If you look at a side profile of an Audi Quatrro, the entire engine is a fair distance in front of the front wheels. Its amazing they handle so nice with the engine so far from the center of gravity.
Yes it's a rather light Solid flywheel sourced from another VAG product modified to fit a 240mm Disc. Depending upon flavors, the clutch/flywheel can hold up to 700 ft/lbs. My only concern is the flywheel is lighter than I would like to see. I'm working with a few flywheel manufacturers to come up with a solid steel flywheel in the 20lb range for 1.9/1.8t use, and of course it will be the most affordable package out there.I was using the stock AWX dual mass flywheel and clutch, I knew that with the added power that clutch wouldn't last longer than a day. The new one was supposed to be a prototype clutch that Scott Dewitt was developing in conjunction with someone else, it's supposed to be a 240mm unit. I hope Scott comes on and talks a little more about it as I don't know the exact details for it yet.
