tomiisp
that oil sensor at oil pan its very tricky, it have digital output, I know how that signal look and what provide and also electronic to processing this I have in mind but I need find time to play with that
I just used the old style pressure switches and threaded them into the filter flange as they're the same thread. That way the light works as it was intended.jjordan11 said:that brings up a good point with the oil pressure switches. I did notice that when I grounded the 80's signal wire the oil pressure light and buzzer went out. Maybe I'll just leave it grounded and go with a pressure gauge instead of the light.
The engine does have the oil sensor, but I wasn't planning on utilizing it unless you know of a good trick to get information from it without the instrument cluster. Are you using it?
Thanks, I should have thought of that. It keeps it simple and working as designed.vwmikel said:I just used the old style pressure switches and threaded them into the filter flange as they're the same thread. That way the light works as it was intended.
IIRC the engine was in the 60-70,000 mile range. Also might want to get with TDIsyncro regarding PD cams, I think he had something brewing.jerry_m said:Nice project!
Sorry to hear about your cam. How many miles does the PD engine has got?
I really have no idea yet...when is the Portland thing? This summer?jjordan11 said:Ok, thanks Mike. I'll try a direct connection to the ecm from the speed sensor. That would be easiest. After I get it going I'll need to have you chip it and we'll do the map based program you have. I'll pm you later when I'm ready for it. Are you planning on going to TDIfest in Portland?
