Jerretxx
Hello, first off - I am new to the TDI world. I have always owned Toyotas & been an off road enthusiast.
Vehicle:
1986 Toyota 4Runner
Solid Axle Swap (Toyota front & rear axles)
37x12.50R17 cooper STT PRO
5.29 ring & pinion gearing front and rear
Spartan front locker
Yukon rear locker
Center force clutch
R150 5speed manual transmission
1.9L ALH TDI Engine from 2000 VW Jetta
.260 fuel injectors
GTB2056 Garrett Turbo w/ electronic turbo actuator (763797 or 6NW 009 543 G-048)
Tekmektronics tuning
2.5” stainless exhaust with muffler
Edge CTS insight module
Fast forward Auto complete wire harness
background: purchase vehicle 3 weeks ago. Swap was already completed. I did not build this vehicle
issue:
At purchase I was made aware of intermittent issue (previous owner acted as if it had only happened 1 time).
Traced all wiring. All connections look great, good connection from ECU to plug.
this engine is not utilizing the N75 valve from what I can tell. It appears that the signal wire from my ECU goes directly to in 4 on my turbo actuator.
I have contacted fast forward auto (harness supplier) but they can not assist. Their harness was designed for stock application with N75 valve not an aftermarket turbo utilizing an electronic actuator.
I have had the issue with both actuators. The original Garrett/Hella & also an aftermarket eBay brand. I am planning to replace the connector to ensure I have adequate connection on the pin 4.
any guidance would be helpful. I have reached out to Ross-Tech considering buying their software to assist with issue.
Jerret
Vehicle:
1986 Toyota 4Runner
Yukon rear locker
Center force clutch
.260 fuel injectors
issue:
- I drove vehicle 100 miles without issue.
- (Day 2) Driving down interstate, lost all power, started smoking a lot, EGT went higher than normal. Parked, opened hood, saw that the connector (5 pin map sensor connector had unplugged from turbo actuator. Plugged in, started truck, no issue remainder of trip.
- (Day 2) Cranked vehicle (cold) had no boost, had no turbo spool, blowing black smoke. Turned truck off, waited 30-60 sec started truck, all was normal. Power returned, turbo would spool, no smoke.
- (Day 2) driving down road, all was well. Stopped at stop sign, upon starting, turbo wouldn’t spool, no power, black smoke. Pulled off road, turned truck off. Wait 30-60 sec started truck & all was normal.
- (Day 4) driving down road, all was well. Stopped at stop sign, upon starting, turbo wouldn’t spool, no power, black smoke. Pulled off road, turned truck off. Wait 30-60 sec started truck & all was normal. Ordered replacement turbo actuator.
- (Day 8-9?) installed new replaced turbo actuator, inspected linkage and actuator linkage moves very free. Started truck, noticed the actuator did not move, attempted test drive & had no power, no spool, black smoke. Parked truck, inspected connection found that pin had poor connection, trimmed plug got adequate connection. Started truck, turbo responded as it should, good power, quick throttle response, no smoke for approx 10-15 mile. Then while driving lost power, turbo won’t spool, black smoke.
Jerret
