So, not *really* related to the engine yet.
I'm done spraying the firewall / engine bay / front floor pans of sound deadener (spray), and new base coat, but needs a few more base coat sprays and clears done.
Also doing the rear floor pans and back as well here. It's all stripped down.
Verified / Stripped (starter interlock relay, etc.) and rewrapped the MK2 16V GTI 92 CE2 interior, steering stalk, and fuel tank harnesses.
I realized my donor GTI front-end harness was a butcher job so obtained one from a friends B4 Passat TDI he was parting out as also a spare CTN TDI transaxle (= I have a B4 ALH done engine harness already.
I think that takes care of most of my CE2 harnesses except Misc **** and how to approach the A/C . . .
What little info I can find, using MK3 controls require a MK3 dash; not going that route too much effort.
I plan to stick with the MK2 AC control panel and dash layout.
I have a CE2 A/C harness from a 91' G60 with the N plug (green single 6pin) and relays, as also a B3 Passat A/C harness with the N plug as well.
From what I'm told the B3 Passat has more safety's, but works same as the G60 harness (OFF/ON). I don't have a Bentley for those only A2 & MK3/MK4.
I do plan to use a B3 Passat rad fan harness adapted plugs for slim-line fans, so it may make more sense to stay with the B3 AC harness.
Still plan to use the MK3 evaporator, condensor, recdryer, and possibly lines (or make new not opposed after watching a few videos).
I'm still unclear on which compressor I should use; MK3, MK4 or a fixed-compressor for the MK2, but then I read late Corrado/B3 had variable compressors. I know S&P as others make adaptors for older MK2/Corrado lines can connect to a MK3 AC compressor.
I also read (maybe here), that the MK3 compressor is variable like the MK4 and you can remove a valve to make it a fixed compressor suitable for a MK2 setup. Again, I haven't got a lot of solid info here, still in the research phase.
Which brings my next question;
Variable vs Fixed A/C compressors, but would the new AC harness allow for proper function of a variable compressor? Or is that determined a nother way; via the control unit? Or by use of the relays? I rather not use the MK3/MK4 FCM as it's overpriced, buggy (when not OEM), and overly cumbersome I felt. When I worked with it on the few cars I fixed issues on it; the diag was easy, unit costs and proprietary lost my interest that route.
I can't "tell"a difference other than the P/N, but I got a later CE2 AC slider control panel which is supposedly required for the CE2 swap as well; not sure if any relation to what compressor requirement.
vwvortex and clubgti have some info (dated), but not many that had to start from the 86 USA and decided to keep the AC. Most just dumped the AC it appears. Or the few that kept AC used a MK2 setup with adapted MK3 / R134a connector ends onto their existing lines; and flushed.
I hope to get done in the next few weeks.
* Have the bay cleaned up rest of way with the base coat/clear and the MK3 cross member installed with the MK2 control arms.
* Install the MK3 suspension and tires to land on if jacks get moved haha. Just makes me nervous.
* Install CE2 fusebox bracket & run the interior harness.
* I got a hydro clutch brake booster bracket for the TDI trans, and cut / marked / mounted the new spot for that. So, that'll get mounted when subframe goes up.
I haen't done **** to the engine, but I figure the "biggest" parts in an engine conversion is all the prep work for installing the engine and driving off
