Loaf
I just replaced the coolant level sensor in my 1986 1.6D Jetta. The old one had a crack in it that was allowing coolant to leak out and drip down the expansion tank. New sensor cost $7 and took about one minute to replace. Bam- no leak.
I though I was winning.
Except...the red light in the temp gauge is flashing. With the old sensor, the light only flashed when the coolant level dropped below the minimum mark. With the new sensor, the coolant level is just above the minimum mark on the tank when cold and just below the max mark when warm and I still get the flashing light. The light will go off it I just cycle the key to off then back on once the engine is warm but I'm not a fan of doing that. I want it to work right.
Any Ideas?
Any Ideas?
