AWPGTI
Ok fellas I'm gonna check that now and report back.... If it is the thermostat I see there is different temp options a high low and a regular would it bennifet me to go with one of the other options?
I contend that if there's actually coolant flowing thru the radiator one hose will be quite a bit warmer than the other......hence giving you two lukewarm hoses...![]()
I'm only half German, not enough intelligence to solve this riddle....I'm not disagreeing that it's the thermostat but... The smoking gun is this whole issue revealed itself only after the heat was fixed and all holes on the blender doors were plugged... I'm curious if there could be some sort of a connection there?
Does the Bentley list a proper operating range?What's considered normal operating temperature for the 1.6d
