1981 Rabbit Pickup ALH 5 or 6 speed Build.
JayWagn03
Georgia
2003 Jetta Wagon, Tdi ALH
Well I adopted another project, couldn’t pass this up. Parked at 94k and was running a few years ago, the timing belt broke at idle on the original 1.6D, 1981 Rabbit Truck. Black with red and white pin stripes on the side. Lots of patina, 0 rust holes. Plans are to get an ALH, VNT17, 11mm pump, front mounted intercooler, 02J or 02A. Possibly stage 4 malone tune, it’s all a pipe dream as of now but I will be using some S & P products. It’ll get rolling once the current project is finished. This car will be my fun car/learning car for making good power that is also very fuel efficient. I’ll take what I learn and apply it to my daily, an 03 jetta wagon ALH 5 speed.
The Cream Dolphin
Fernie, B.C. originally Dwight, ON
02 VW Golf TDI ALH 245k
Oh yeah, I am excited for this one
JELLOWSUBMARINE
yes
Wish you well. A worthwhile save. Very few decent pickups left.
Zak99b5
Albany NY
2003 Jetta TDI
Sweet. I’d matte clear that thing just as it is. Looking forward to the build thread.
JayWagn03
Georgia
I thought about that too, I think I’m going to touch up the pin stripes, possibly bring back the tailgate some to match the truck more then use some kind of seed oil to preserve it. Haven’t looked into the process yet but yeah I don’t want to change much about it.
Bradm
Wisconsin
02,03,05, Jetta 99.5 Golf
Follow up with what you end up doing please, i have a truck with the same patina that ive been debating what to do with. Im not too keen on sealing it up with a clear, seems like a bad idea. Ive been looking into this stuff called patina paste, it’s relatively cheap but ive also been researching homebrew paste/oil mixtures
JayWagn03
Georgia
I was told to wipe it down with degreaser, then wipe it down with boiled linseed oil. Still debating but I will probably do that unless I find out it’s a big no no. I don’t want to do anything to it with how bad the pollen is right now. It’s stored outside, washed it really good on the way home and installed new side markers. Still haven’t figured out what kind of wheels are on it. I was told they look like knock off bbs wheels from the 90s and there was a date on the back. But back to tdi stuff… I have a lead on a donor car, 2000 automatic with a brand new auto trans and 11mm pump. Haven’t decided if I’m getting it yet but I’d like to.
JayWagn03
Georgia
Might I add that there are SEARS brand tires on it, with slashed looking side walls. They’ve been holding air over 36 hours now :ROFLMAO:
RexNICO
South West OH
2011 Tiguan (13 Jetta sedan eng/trans)
Are they whitewall on the opposite side?
If so, I had a similar style of "boat trailer" tires from Sears on a Chevy Vega back in the early '80s. I think the slash was supposed to make it look like rope.
Seeing this makes me wish I still lived in Georgia/the South where you can find 30-40 yr old cars that aren't crumbling.
JayWagn03
Georgia
No the sidewall was peeling off showing metal in the tires. I’m out of town this weekend but I’ll get some better pics. Still haven’t searched for tire manufacturer date.
JayWagn03
Georgia
For the fun of it what would y’all run for trans? 6 or 5 speed? I was thinking about putting .681 5th in my wagon and would do the same to the rabbit if I went that route.
burpod
teh stallionz!!1
cape cod, ma
for a rabbit, i would suggest the eurotuning.cz 6spd add-on kit with an 02j - or you could do an 02s 6spd from a gasser. eurotuning is what i did in my rabbit ahu swap. much simpler than fitting a (heavier) 02m in there... drives so nice especiall with LSD installed at same time while trans is apart for surgery
JayWagn03
Georgia
Noted. I’ve gotten a good amount of parts from this wrecked tdi golf. He had this fuel filter adapter that I’ll post in a few. It takes a Caterpillar 1R-0750 filter. Thinking about using that along with the original rabbit filter housing.
