I have been searching for an answer for my problem and hoped someone with the same problem has fixed it. I drove my 99 Beetle home from work and filled it up. When I restarted it it revved up popped and then idled normally. I drove home and had very low power. I re-started the car, same symptoms - revved and popping, then idled normally. I used my scan gauge to check for codes and there weren't any and there was no check engine light. I thought maybe I got a bad load of diesel, so I replaced my fuel filter. Still had problems and low power. I replaced my fuel sending unit. Still low power. I used vag-com and got 17945 - Fuel Shutoff Solenoid (N109) P1537 - 35-00 - Malfunction. I cleared it with Vag-com. Drove it and the power was back. After shutting off, I thought I had fixed the problem, but the next start it was back, and the code was back. Only resetting with vag-com would work, and only after it was cooled off would the code clear. I replaced the N109 solenoid with a new one. The problem came back after the next test drive and shut down. I cleaned the grounds under the battery and at the ecm. Still have the problem. I have changed the air filter, no blockages, and also changed the fuel filter again.
Thank you!
Thank you!
