15 GSW CRUA Oil Pan Gasket
Freeze Plug
CT
Turd Sandwich
New to me 2015 GSW 6MT, 244k miles, small oil leak at the lower rear of the engine, near the auxiliary coolant pump. looks like it’s the upper oil pan to block gasket. I can’t find any gaskets available, was this factory sealed with an RTV or similar? If so, does anyone have a lead on the proper sealant and procedure?
Freeze Plug
CT
Turd Sandwich
At first glance my guess is yes, looks like the trans bolts to the block and to the upper pan but I haven’t had time to look any further yet. Hopefully it’ll just drop out
sardo_67
CT
2015 Golf SEL 6spd
i just pulled mine apart and it's just glued on with an RTV of some kind
sardo_67
CT
2015 Golf SEL 6spd
Did you have to drop the trans?
engine was on a stand, i am not sure if you can reach the 2 bolts by the crank or not though, i think you can as there are holes in the casting. you can go under your car and look
turbobrick240
maine
My Ford/Navistar 7.3 needed an RTV oil pan "gasket" when I replaced the rusted oil pan. A lot of the experienced powerstroke guys swear by the Permatex, the right stuff- product. I had trouble getting the motocraft sealant from Ford to make a good seal, but the Permatex right stuff worked great.
IDoSeaDoo
Raleigh, NC
2011 Jetta, CJAA 6spd
FYI, I completed this last night. All bolts accessible while engine is in car, with no special tools just a 5mm Allen with ball end for the two bellhousing bolts
Did you leave the transmission in place while you dropped this part? Did you have to remove the oil cooler and filter housing too?
Freeze Plug
CT
Turd Sandwich
PM’d you. Trans stayed in place, did not remove oil cooler or filter housing
