1400 miles (2254 km.) on 1 tank!!
TDI_bubble
phx
98 tdi bubble
I could see 50mpg being "awesome" at 90mph but that would mean your ALH is inside a velo bike.
Your tank of diesel 2 got you to almost 1,000 miles at 90mph?
I'm calling bull****.
rotarykid
Piedmont of N.C. & the plains of Colorado
1997 Passat TDI White,99.5 Blue Jetta TDI
I have no trouble what so ever getting 50-52 mpgUS @ 70s- low ~80s mph in my 97 Passat TDI tank after tank . I don't see that it would be a lot lower than that if I were able to push it to 90 mph for any length of time . . And I always see low to mid 50s mpgUS in it on city only loops around Denver . Have achieved low 60s mpgUS several times in B4 Passat TDIs and A4 Jetta TDIs on city only loops in Denver and in southeastern coastal NC lower speed only loops .
And I've clocked similar mpgs on higher speed loops under the same conditions in a A4 body ALH engine Jetta TDI . I'm careful about how I drive and I always drive for maximum mpgs . So I have never seen below the mid to high 40s mpgs in any manual trans TDI of any body under any driving conditions @ any speeds .
So under the right conditions if care is taken these numbers are not bullsh!t at all , more than achievable .
Digital Corpus
Ontario, California
'97 B4 w/ 236K mi body, 46K mi soul
71.1 mpg means he really got 59.2 US mpg in a passat since converting from Imperial gal to US gal brings those numbers into something more sensible.
For Hwy driving I have strong doubts as to getting 60 mpg unless level driving is achieved all the time or drafting a semi is done for a considerable amount of time.
As for my commute, about 27-28 miles one way, I travel from ~800 ft to 1000ft, down to 850ft and then back up, and finally down to ~140 ft the latter 40% of my drive. There are 4 areas which I can get about 3.7 miles of coasting without slowing down or minimal enough to be offset with a pulse and glide technique of driving. My best ULSD economy was 57 mpg driving at 55 mph, drafting a semi and pulse+gliding the above. My best repeatable economy is 54-55 mpg doing this route at 55 mph. I'll drop down to 50 mpg if I drive the speed limit of 65. I'm a skeptic of your numbers as well rotarykid because if I apply the same unit conversion of Imperial gal to US gal, your numbers then match mine.
hskrdu
Maryland and New England
Not sure about Jim Martin's numbers, but rotarykid has been an MPG leader for years, and fully documents his MPG. Just b/c your FE doesn't match his isn't really cause for skepticism. My GF has had two different Jetta ALH's, one a Mark IV 1999, the other a 2003. With similar driving conditions, the older had a "lifetime" average of 45MPG over mixed but mostly hwy driving. The newer one, with almost exactly the same conditions, got 54MPG on it's first trip, and has an average of 52 MPG so far. Same drivers, same roads, same fuels, etc. When I drive her car, I beat my 2003 Golf's FE numbers by 2-3MPG every time. Some cars do better than others, and some drivers can get the most out of their car.
yatzee
Montreal, Qc
see sig
I got 71.1 mpg for 38380mi. with my 2000 Jetti TDI driving like a bat out of hell over mountain passes on the interstate highway system mostly in Colorado and Utah. Advancing the timing was the only alteration to a fully stock 125 hp. TDI. Most of my driving was in excess of 90 mph. I had the timing belt replaced and my car was re-set to factory specs dropping the mpg to 56...have not had the time to re-advance the timing..some trial and error involved.
sorry, but that's impossible. I've owned a bunch of tdi's (1998,2000,2002,2004) and i've never gotten close to that.
mohawk69
Richmond Hill, GA (Savannah)
1996 B4, 1996 B4V, 2000 Beetle TDI
You don't have enough info yet (and neither does anyone else). My mileage goes WAY UP in the mountains. Yours will be much higher too if your willing to exceed the unreasonable posted speed limits. In some cases exceeding 100 moh is easy while idling.
piperpilot26
cheshire ct.
89' jetta diesel
wow, these are all great numbers you guys are hitting! the best I've been able to get out of my 89 jetta diesel with the 1.6n/a is 54mpg. Of course thats keeping it between 55-60mph on the highway.
rotarykid
To get maximum mpgs ;
I use a rolling start out of the garage to start the engine when the engine is cold to avoid battery drain that costs fuel to recharge ,
I skip gears ( 1st , 3rd , 5th most of the time ) and use rpm matching to shift ,
I use "N" when ever possible especially on city loops and when the engine is still cold I kill the engine when coasting in "N" using built up energy to restart when acceleration is required ,
I look down the road to avoid ever if possible over accelerating just to have to brake ,
I install a lot taller than stock tires ( 205-215/75 __" ) along with low mass alloy wheels ( as much as 5"-6" or more taller than stock as much as will fit under the lower end of the shock spring platform without rubbing ) , This not only helps top gear but helps all the gears be taller . If care is taken on take off this one thing can make up to a 5-7+ mpg difference in achieved mpgs over stock tires & wheels . This kills takeoff but that isn't why I drive a diesel anything . This change also can/will under cartain conditions increase stopping distance so you must drive accordingly ........This isn't a modification ( as much as I do it ) that I would suggest to someone without specific driving skills or knowledge . You must know how to realign the suspension to raise the car above factory height as much as I do . A skill which I learned how to do when I drove and worked on race cars when I was young , a skill the average Jo's blow mechanic doesn't have . The extra strain of the taller gearing and advanced timing can/does lead to head gasket failure if pushed !!!
I install an air dam to keep air from getting under the car due the need to raise the car up to fit taller tires ,
And as described above a real biggie in achieving these numbers is the fact that I jack the timing to really early BTDC to maximize energy gotten out of every gallon of fuel .
By themselves most of these things don't add up to a lot of improved mpgs . But when added together these things can add up to a 10-20 overall mpg improvement . A small increase in tire size along with a moderate timing advance can get you an extra 4-7 mpgUS pretty easily . That is as far as most want to go to avoid the blown head gaskets and other modifications required to push things as far as I do . A 3-5 mpgs or more increase can achieved pretty easily with just extra care taken in how you drive ( using the shifting things I've spoke of along with care not to accelerate just to have to hit the brakes ) without changing a thing on the car .
john.jackson9213
Miramar, Ca. (Think Top Gun)
1996 B4V
Rotary Kid,
What kind of final drive ratio are you running? How many miles/K rpm?
Planning to use a .622 fifth gear upgrade. Running 185/70x14 tires also.
If you can run it in Colorado, I can run the same gearing in San Diego. Need to look at bumping timing up like you. Hammer mod???
Used to have a 74 RX3 - got it new. Was a real kick to drive. MPG sucked, but that was why I got my 76 Accord - Best MPG was over 47. No kidding. Low 40's were normal.
Best car I ever owned for the first 50K miles. Then I let a dealer do a recall on the car. It turned into a huge POS immediately after that.
rotarykid
I haven't changed any of the internals , just installed taller tires which makes all the gears taller .
I owned a wide variety of Rx's when I was young , 2s , 3s , 4s & the 5 ( Cosmo in the US ) . I even had a R100 for a short period of time in the late 70s . My daily driver in high school was a 74 Rx4 , heavily modified :). Man that thing was fast ......I really wish I still had that Rx3sp too , now that was how a sports car should look ..Never cared for the 7s , were just too small for my tastes . That late 80s 7 that had the 13b along with other model only options was a nice one .
With timing , gearing changes , a modified thermal reactor and a lot of care in how they were driven the rotarys could be coaxed into the low 30s mpgUS . With a few mods they would turn 12k+ rpms and push the car past 130 mph too which was fun . I used to eat small block chevys for lunch , the really fun part was showing them what had just blown their doors off .That 12a & 13b were good engines that would take a lot of abuse .
RalphVa
Virginia
Jetta
The computer showed only 54 mpg last weekend on the trip back from Waynesboro with a lot of it down the mountain to Charlottesville. Mileage up was 44 mpg. The reprogrammed new module they put in at the 10k service is really showing up.
A Passat is a heavier (just a bit) vehicle than our Jetta.
ChetsJug
San Fernando Valley
2001 Golf Diesel ~ the last Mark-IV ~ i think :p
Sorry I'm late to class... hehe
When I went to a vocational school, the teacher was a retired GM engineer. He told us about the test track speeds for mpg testing. He used to work at the GM track in Arizona or NM (i forgot where it is). Point is, they do many things. No they dont take the back seat out. lol - But, they do get a 105 pound soaking wet driver, use 1.1 gallons of gas and they do drive at 48 miles per hour. This is a small margin below the speed where wind takes effect on the car.
At these speeds a square cube will get 30mpg! Let alone an "aerodynamic" car. In my gas cars I drive by a vacuum gauge and I've noticed that 50 to 55mph is where the wind drag takes effect. I had a Ford van bubble top camper conversion with a 351 V8 that was quite heavy. It got 16mpg at 50 but, by 60 it dropped to 12. Needless to say, I did NOT drive that truck at 70! Wind did have a profound effect on mileage.
If driving a turbo diesel I would install a turbo PSI gauge if you don't already have one and pay close attention to it to see what speed you see a upswing on the pressure curve.
Can anyone find out what speed VW tests these cars on the track? The factory tricks would be very interesting to know :)
thsheet
Mount Forest, ON, canada
2014 PASSAT
Envy is a harsh mistress.
I envy a harsh mistress...lol
anyways, I just bought a 2014 manual Passat, it's on order from factory, because few people buy the manual.
My 125 kilometre long route to work IS done at 90K, I cannot wait to see the mileage at a forced 90KPH! I expect the fuel consumption to be ½ my guzzling '05 Altima...
It's been 7 weeks waiting for this car, I need it to arrive soon, or else I will get carpal tunnel syndrome for checking my phone for messages from the dealer repeated times.
thesheet
SSmike1
Milwaukee
96 Passat TDi
i just bought a 96 Passat TDi, and it is getting 52MPH highway!
I went on a 900 mile trip on one tank of fuel. WOW am I impressed!
Hyde7278
Central Mich
2001 Golf GL
Are you taking in to consideration the error in the odometer caused by your taller tire. If not your MPGs is definitely off
rotarykid
that is a given, the entire purpose of going taller skinnier is to get less turns per mile.....you can easily figure out how many less turns per mile compared to stock the gearing change gives you.....
Here is the thing that muddies the water here, every odo has a built in error usually high showing more miles than you actually have traveled.... So you must always before you make any calculations must figure out the standard error in the odo by design. Then take that data to figure out what the change in gearing gives you.....
Then take that data to come up with a number to multiply the displayed traveled distance by to get the actual traveled distance. Once you have actual traveled distance of the tank divide by the amount of fuel the car takes to refill....
Then wala! you have your actual consumption number...
RIP TDI
Santa Barbara, CA
2015 GSW SE 6MT 2001 Golf GLS 5MT 1996 Passat Wagon
Or if you object to fiddling with the numbers at each fill-up, do it the elegant way; install a pulse frequency interface in the VSS line, calibrate the odo, then finally independently calibrate the speedo by reindexing the needle. An $85 solution and well worth it (to me anyway) to not have to use correction constants at fill-up and put up with an inaccurate speedo.
rotarykid
I used to use a Garmin 700 series as the speedo & odo(the 710 is the only model that gives miles and tenths of a mile on the clock so is perfect to figure out actual miles traveled per tank). I used it every day for ~3 years attached to my display over the speedo before I settled on the larger screen 1400 series units I use now.... EcoRouteHD connected units can give miles and tenths when connected. But when not connected they round the miles....
Today I have a Garmin 1490LMT with the ECO-RouteHD OBD-II connected to the gps suctioned to the display. I use it set to speedo, engine water temp, boost, throttle % & rpm so I have the exact mph all the time without worry of speedo or odo error.....I have a 1450LMT I use for maps attached to one of the air vents.... These 5" display models really make the displays, maps ect.... easy to read, compared to the 4.3's!
I have played with many Garmin models bought cheap off of craigslist over the last ~6 years. I bought the first garmin I ever got on craigslist, lucked out when I had no clue what the difference was from one series to the next with a top of the line 700 series for cheap. It was a 710 with traffic that needed the battery wire fixed, it appeared to have a bad battery. Took it apart only to find that one of the battery wires had frayed. Fixed that returning normal 5 hour battery function. Used it every day for ~3 years as my speedo and odo then sold it along with the one's I no longer needed there. The 710 was one of the best most equipped models ever sold by Garmin. I put it on craigslist at what I thought was a outrageous price hoping not to sell it. But to my surprise it sold in less than a week for exactly what I was asking! I should have asked more.....
I got more when I sold the 710 than I had actually paid for the other ~7 I have bought & sold put together. I actually have made a few dollars in playing with the different models and the switches from one to the other.
I have had a 255W, two 700s(710 & 760), a couple of 1200 ( a 1250 & 1290), a couple of 1300s(1350 & 1390) and four 1400 series units....
I like the the Nuvi 1490 for the larger screen which is easier to read at a glance. I would not have thought that 0.7 inch in screen size would have made that much of difference but it really does make it easier to read.!..
