13 Jetta TDI - High Pressure Fuel Pump
stephchase
West Palm Beach FL
2013 Jetta
It appears this was an issue in older models up to 2012. I am being faced with repairing the high pressure pump, injectors and cleaning out the fuel tank. $$$$ I am also still waiting on Volkswagen buy back since October. Had that happened quicker I wouldn't be faced with this costly repair. I am fighting hard to get them to step up on this repair and no luck yet.
Anyone have this issue??
turbobrick240
maine
Yes, the factory hpfp is a weak link in the design. If you can't get VW to step up to the plate, I have a good used hpfp that I would let you have for the cost of shipping. I upgraded to the cp3 hpfp, so have no need for the factory pump.
forrest resto`s
athens ga.
2000 jetta tdi auto rc2 2013 passat tdi 2015 passat tdi auto 2011 jetta tdi nav. s'roof..man. dpf delete 1970 GTO JUDGE 520 HP
just curious.. how many miles on your 2013??.. Thanx.. the 2009-2012 (i believe) have an extended warranty for 120,000 miles for the pump...not the 2013 and later..
maddog468
Florida
2011 6mt
I have 2011 tdi with about 110k miles and I believe a HPFP issue. Random surges and stalls. Never been to vw to ask them about buying the car, because I wanted to keep it.
I am the second owner of the car and the misfueling guard kit was never installed by the dealer. Until today I did not even realize that the kit even existed or big problems with the HPFP. I did trim the plastic guards inside the filler neck. I think if I installed the misfueling guard it would hide what I have done.
So I have the same questions,
Go on eBay and buy the misfueling guard kit and take it to the dealer to see if they will warranty the HPFP.
Drive the jetta to dealer and trade it in?
or
Replace the HPFP or mod the jetta for the CP3 fuel pump kit on my own dime. Whats the going rate to do this? Does modifying the pump give up any recall rights?
Thanks for your help.
Nigel F-H
Riverside CA. USA
2014 Passat tdi
My 2014 (Build date Sept 13) Passat HPFP failed at 60,846 miles. After many calls to VWOA I managed to get repair cost cut down 50% to $3,000.00.
Please Please file a complaint with NHTSA at safercar.gov Find the "Vehicle Owner" Tab, then click complaints and defects tab...
If enough complaints are filed VWOA will have to extend warranty. My car broke down in middle of 6 lane freeway, no warning.
Unfortunately as many owners are dumping their TDI's I fear that not enough complaints will be made.
ZB657
Chicago
2012 VW Jetta TDI
Yeah, I had this HPFP issue last year at 48,542 miles and only had the car two months at that time. My car stopped after I pulled over when I saw the coil light flashing. After a few minutes, it cut off and I couldn't keep it on after that as it would turn on and then shut off again.
It's a comprehensive repair...8k worth. Fuel lines, tank, pump, and all the other components that pertained to the fueling system was replaced. They did a test to make sure the fuel was diesel and repaired the system on their dime due to it being a faulty pump. Hopefully you get the same treatment and it shouldn't take no more than a week to get it repaired. It should be covered under warranty though if it's relatively new AND you didn't misfuel (which would be impossible nowadays).
Good Luck bud.
turbobrick240
maine
Probably because the bean counters were trying to control warranty expenses.
Brasso
USA
2013 Passat TDi
I had the same issue with my 2013 VW Passat TDi with 111k miles, VW Dealer called it a catastrophic failure of the fuel pump, quoted me almost $9000 to repair....Car is still sitting in my driveway....
KCL-WA
Seattle
2013 Passat
At 6 am on 7/3, as I was driving my 2013 Passat to work on 5 lane freeway, my glow plug pigtails warning light came on and I noticed a significant decrease in power. I barely made it from middle lane onto right shoulder before car engine shut off. I was only an inch away from right lane. I was stressed, scared and afraid to get out of car and afraid I would get hit. AAA towed to dealer. Diagnostic showed complete failure of fuel pump and they found metal in lines so the entire fuel system needs replaced. (Estimate is $7K). This is our 3rd VW (87k miles) and second TDI. We know how to maintain cars (fill up whenever we are at half tank, use reputable gas stations, etc) and we service regularly at dealer. I created an incident report with NHTSA per recommendation in this forum and will be calling VWOA on Monday. I need to get car fixed but sharing so others know the failure of fuel pumps is ongoing. I hope VWOA makes this right.
Tuheeden
North Carolina
2013 & 2014 Jetta sportwagon
These forums are full of CP4 fuel pump failures and it's a very expensive repair. Unless you have a warranty of some sort, I don't believe that VWOA will do anything as that is not an emissions part and even if it was your likely out of the extended diesel gate warranty.
Let us know what they say.
