12v power outlets always hot
Dunno513
Mirror Lake, NH
2006 NB PD-TDI DSG
both my 12v outlets are always on. While this is great for my gps, it isn't so good for my camera which depends on a switched outlet for proper operation.
Not finding a lot on here except for the few who say its sometimes switched and sometimes always hot.
Just wondering if there is a vagcom procedure to change or if maybe there is a relay that can be switched out to a different one to allow my outlets to be switched off when the key is off.
06 NB BEW platform.
compu_85
Gadget Guy
La Conner, WA
... None :S
This isn't a setting... the power for the 12v outlets is simply hooked up to constant power.
If you wanted to take the fusebox apart you could hook them up to switched power.
Mike_04GolfTDI
Richmond, BC, Canada
Mine: 2019 Golf R DSG, Wife's: 2015 Golf Comfortline TDI
Too hook up my dash cam in a MkIV Golf, I just found an unused switched terminal in the fuse box on the left side of the dash (accessible with the driver's door open).
I got an inline fuse holder, crimped a flat blade connector on one end, plugged that into the fuse terminal, and used that wire to power a 12V lighter-socket splitter type device. Then I plugged my camera into that. It all tucks neatly behind the dash, above the fuse box.
wonneber
Monroe, NY, USA
On my 03 5 speed the outlet gets power from the load reduction relay which should shut off with the key.
An Automatic gets power from the park-neutral position relay.
Not sure if your 06 is the same.
Try pulling the relay out to see if the outlet goes off.
