KanPanic
Hey guys my pump isn't following the specified timing all that well. No leaks drives fine daily. It maybe leaking by the timing piston. My tuner says we won't be able to control boost with the injection timing so erratic.
Here's what I've got and what I've done:
11mm pump (car was originally an auto 80k'ish)
Static timing slightly advanced just a little over the blue line
R520 injectors set up by DBW
New fuel filter
Pressure relief vale repaired and still together.
Ran a can of Diesel Purge through it.
Here's some logs: I divided the N75 and Cold start values by 10 so they would plot better along the left side axes.
Has anyone had similar issues?
Has anyone solved this by any other means than replacing the pump?
Does anyone think a lift pump would help?
New fuel filter
