is there a way to visually tell the difference between these two...i am considering buying one that was supposedly rebuilt, wanna make sure i am getting an 11mm ip.....thankyou
10 mm will be '404' in the 0 460 XXX 987 number, 11mm will be '414'
Be advised, there are only a handful of places who are authorized and have the proper equipment to rebuild our pumps. Minimum cost (approx) would be around $600 and up to $1200 dependent on condition. There are also cheap, Chinese knock-off parts readily available. You're going to want to make sure none were used on this pump. I'd get more info about the pump and the rebuild before pulling the trigger.
ya, due to the chinese junk issue, I plan on only getting one from a known working engine part-out, bone yard, or just get a rebuilt one from a reputable source.
I'm not aware that anybody has made more power with original Bosch parts than hatemi got with CHINESE cummins VE pump head. 295 hp and there were still plenty fuel to be had...
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
