Andyinchville1
Hi All,
I used to change oil per factory recommended intervals. However , after learning about oil testing labs in the forums, I decided to try longer oil change intervals and get my oil analyzed ... I figured since I do easy highway miles this should be ok .
So far I have pushed to about 27k miles on an oil change and the lab results seem ok ( I know for a little more $$ I could have just changed the oil but that would sometimes happen at bad times .... like freezing cold out , super hot out or when I'm plain too lazy to do it ! :-0
I know bad excuses ... but if I could pull off doing fewer oil changes and the engine is still ok with it then that's what I lean towards ... on the other hand if the lf about results said to change oil more I would have to maximize engine life ...
I cant necessarily understand everything in the report but the lab seems to think things are good except maybe lead and the oil being a little thick.
Has anybody gone much further than 27k on an oil change? How were your results?
I am running 5 w 30 rotella in the blue jug .... anything better out there with proven results ?
Would an auxiliary low micron bypass filter help things?
Thanks for any and all input.
I'll try to post my lab pic here but not sure I can .... I did put a pic in the media section under my user name tho .... pics have always been difficult for me on this site.
Edit ... I got lucky and seemed to be able to get pics on here
Andrew
Andrew
