skinnyb
34 k this weekend. No issues other than getting a new seat bottom at around 15k (squeaky) and a new fuel filter canister at around 25k.
You jinxed it!Literally nothing new to report...
-J
What is the mount called?You jinxed it!
Sunroof drain leak? It's not coming from the door seal...
Going to the dealer on Wednesday morning to have this looked at and the radio update done.
66,500????????glad to hear! My sel is at 66,500 and still going strong. No real problems to speak of, had a problem with the rear window going down and not up but was fixed under warranty. Other than that she is cruzing right along. Lifetime average for me is 37.1 with a high of 44.2. Lots of 75+ highway driving in that.
I certainly hope so!Cool! Do you expect to keep it until 222222? I hit 17171 this morning.
TheGrove drives a lot! IIRC his daily commute is 2 hours each way.66,500????????
66,500????????
Yep I commute from Breezewood PA (Where I-70 meets the turnpike) to Rockville MD. At last check I'm up to just over 70,200 at this point.TheGrove drives a lot! IIRC his daily commute is 2 hours each way.
My apologies to Alexandria VW. Shame on ME! The spilled AdBlue in Compu85's car was courtesy of Springfield VW. My mistake.compu 85: Was the spilled AdBlue courtesy of Alexandria VW? Shame on them. I continue to be pleased with Stohlman, but in fact, they've not done anything terribly complex yet...only oil changes, AdBlue, mount tires on rims, FE alignment...also put foam shims under the "fender" dash trim...
So I just finished tearing the interior apart, installing some wiring, and putting it back together. Some observations:
I can see how they were able to trim cost and production time out of this car compared to the mk4. I'd say there are 3/4 to 1/2 as many screws in the interior in the NMS. The design of clips is simpler (not worse, just less complicated. Most things are attached with a simple metal spring clip). The carpets are a bit thinner, and areas that aren't seen aren't painted. Attachments and design of the rear seat are more simple.
I did some of the disassembly in the cold, and only broke 2 clips which were the fault of me not knowing how to release them, not the design. That no plastic parts broke or cracked while I was working with them speaks volumes to the material quality.
There's fewer trim pieces overall too. Smaller trim pieces are combined into larger single ones. Fewer pieces means fewer chances for rattles... hopefully that holds true!
Doing this has made me like the design of the car even more
-Jason
One problem has cropped up... the car seems to drain the battery rapidly. I'm thinking it was a bad battery... I'll replace the OE battery on Monday. I imagine the high underhood temps bake it at a faster rate than the older cars.Here are some pics from our 60K service...
Nice and clean inside
Fuel filter doing it's job
Air filter doing it's job
Primed the fuel system with the VCDS output test for the fuel system electronics (didn't pre-fill the filter housing). After about 30 seconds all of the air was purged out and it started right up.
