ninedee_golf_tdi
So much for the discussion of why it can't be done.
I kinda figured that the thrust bearings wouldn't be up to it, lol little tiny things that they are.The gear reduction is more about available power at a given engine speed. A continental O-200 displaces 201cu/in, so a 3.2l 4cyl. Naturally due to its displacement, you cant spin the thing very fast, so it is tuned for 100hp at a max of 2800rpm. Cruising rpm is around 2300-2400. those engine speeds are good for a standard size/pitch prop. The diesel wants to spin a bit faster for max power, closer to 3500rpm, so the gear reduction is necessary to achieve a good takeoff rating at 3500 rpm and good fuel economy at a 2500-2800rpm cruise.
You could theoretically just use a finer pitch prop, but other factors get in the way. The prop tip speed can become supersonic at max rpm, this destroys performance and is very loud. Another problem is that the automotive engine does not have sufficient thrust bearing capacity to deal with the loads imposed by the propeller. The gearcase is designed with rolling bearings on the prop shaft to accept the thrust loads.
