Piet skiet
Hi guys i would like to find out if injector cleaner that gets added to the fuel can cause the car to smoke when cold and when accelerating?as i have only starting to see some smoke now that i have done that is it normal?the capacitors that ive read about behind the lcd on the cluster that causes the lcd to shine very dimm when hot inside the car is there any type of code for them or specific name and how many of those caps are on the back,i would like to replace mine but would try and order here in south africa first if someone has some info regarding those caps.thank you
