Hi everyone,
I would desperately need your help with the following issue:
I was driving on a back road at low speed and revs when I heard a loud bang from the front left of the car. I pulled over immediately, but in the heat of the moment I can’t remember if it stalled or if I turned the engine off myself. Started the engine again, it idles smoothly, it may be a bit louder like it has a minimal blowout. Barely noticeable.
When I tried to move the car to a safe spot it immediately stalled upon releasing the clutch pedal. When I started the engine again and tried again with applying more revs, the car barely moved and there was (if I recall right) black/grey smoke coming out of the exhaust after trying to slip the clutch a bit. The car was towed home after that.
Tried to start again on the driveway and look for solutions. The smoke is gone, the car is able to crawl forward and reverse with partially released clutch. Once I release the clutch fully it stalls. Still idles smoothly, no fault codes stored. I inspected the boost pipe and the lower pipe going into the intercooler in place. Both looked and felt intact. Will have a closer look tomorrow after I purchased a trolley jack and an axle stand.
The complete clutch kit including DMF and slave cylinder was replaced two months ago with Valeo parts (the slave cyl might be a different brand, the mechanic didn't specify).
Would you have any ideas or pointers what could be the issue? Thanks in advance.
